Also I usually just refer to it as the back side of the power curve because when does anybody ever say "region of reverse command" outside of private pilot ground school?
Think about what's happening. What happens as AOA increases?
I am working on my CFI rating and am having a difficult time putting the concept of the region of reverse command into a logical, easy to understand explanation. Any thoughts or ideas you guys have used to explain this would be greatly appreciated. Thanks.
Mo lift, mo drag! One of my favorite things to discuss with students because many things that happen correlate to that.
Houses get smaller?That's not entirely correct though. That's why I referenced AOA.
Houses get smaller?
In simple terms, higher AOA = higher induced drag. So in the region of reverse command, increase to pitch (higher AOA), and the airplane descends, rather than climbs because there isn't enough power to overcome the increased drag.
Houses will have to get bigger before they get smaller in order to get on the other side of the curve.
Higher AoA = higher lift as well right? Induced drag is a 'by product of lift' to use the FAA definition.
BETA!!the concept of the region of reverse command in a logical, easy to understand explanation
Planes stall when they go to Fargo?It should. Unless you take it to far. Then, it stalls.
Do not use this description on your students (well unless they like math), but the engineer in me has to...
Induced drag is related to alpha (AOA) because (shamelessly stolen from https://en.wikipedia.org/wiki/Lift-induced_drag#Calculation_of_induced_drag)
This is the same format for the lift equation and the drag equation, where 1/2*rho*V^2 is dynamic pressure (rho is air density and V is the velocity of the oncoming air). S is the total area of the wing (chord length * wingspan for any rectangular wing Cessna or Piper). C,Di is the induced drag coefficient, which gets its own equation:
Here CL is the lift coefficient for that wing, e is some wingspan efficiency knockdown, and AR is Aspect Ratio, which is:
Where b is wingspan and S is total wing area (above).
So finally what this all comes down to is that CL (and the 2D version, Cl) depends on angle of attack (alpha). And for every airfoil shape there are graphs for Cl vs. alpha, Cd vs. alpha, Cm vs. alpha (pitching moment), etc. Here's one for the NACA 2412 airfoil used on the Cessna 172.
Long story short... Angle of Attack (alpha) drives lift coefficient (CL). Induced drag is a byproduct of lift (and thus the generation of wingtip vorticies), so CL drives the induced drag coefficient, CDi. The the induced drag coefficient gets multiplied by the wing area and dynamic pressure (based on airspeed and density) and gets you the actual induced drag force Di, in pounds. It's really not too bad, the extra variables are just fixed values based on the shape of the wing.
