Alanna
(nice "YOLO" shirt at 2:50)
I'm all for NASA and science and safer skies, but I can only hope NASA doesn't need to drop too many more airplanes for research. A cool project nonetheless.The Cessna 172 airplane dangled 82 feet in the air – looking almost like it was coming in for a landing, except for the cables attaching it to a huge gantry at NASA's Langley Research Center in Hampton, Virginia.
Technicians had hauled the 1958 vintage plane to that height, so researchers could drop it to test four emergency locator transmitters (ELTs) installed on board. The research, funded by the NASA Search and Rescue Mission Office at NASA's Goddard Space Flight Center in Greenbelt, Maryland, is designed to improve the emergency transmitters' performance.
They picked the Cessna because it is the most common general aviation airframe of all time and ELTSAR research revealed no correlation between ELT performance and any particular aircraft. In fact, the team secured three Cessnas for three different tests from private owners willing to sell their aircraft for the sake of research.
The first drop test, conducted July 1, simulated a controlled emergency landing on a highway or runway. The plane, equipped with two crash test dummies, fell at 72 feet per second onto a concrete surface. Sensors inside collected 64 channels of data, while 40 cameras inside and out recorded the crash.
Early results showed only one of the four transmitters went off and started sending location signals within the first 50 seconds. The others triggered a short time later.
"Everything worked," Stimson said after it was all over. "But the team will take some time to sort out why the ELTs performed the way they did."
Researchers will apply lessons learned from this experiment to get ready for the next drop test, which is expected to happen later in the summer. In the meantime analysts will use the data collected to validate and correlate computer crashworthiness models. Those models could be a big help in trying to determine the best way to install emergency locater transmitter systems in the future.
Kathy Barnstorff
NASA Langley Research Center
Last Updated: July 4, 2015
Editor: Samuel McDonald
Full article: http://www.nasa.gov/langley/crash-test-assesses-plane-emergency-locator-transmitters
