ctab5060X
That's pretty interesting. I never knew any of that. Thanks for the info.
@killbilly
Highly suggest you read Whistling Death: The Test Pilot's Story of the F4U Corsair by Boone Guyton.
It's not just singles. It's most anything with props that rotate in the "correct" direction (oppose airplanes that have one engine rotating in the "inappropriate" direction so that little Timmy can get his multi rating).
The Twin Bonanza, whose engines rotate in the "correct" direction, requires some right rudder on takeoff. It's not hugely pronounced, IMO.
The Brasilia was very pronounced when a power or airspeed change was made - the rudder needed to be retrimmed right away. You would hold considerable right rudder during the takeoff roll and initial climb. Many units of trim were required once airborne to get it set straight.
On the C-46, if you bring the engines up together, you may find yourself off to the races. I've not had the pleasure, but my immediate family and friends have, and you lead with the left throttle just a smidge.
The TBM-700 has a yearning to roll and yaw when you make a power lever change, which means if you cob the power at low speed, you might have some "fun" once things start catching up.
Our SOP was aileron/rudder trim zero/zero, although most of the airplanes needed a unit or so either way of aileron trim because, well, crooked and bent.The Saab took 1.5 units to the right for takeoff, set at the gate prior to departure.
As far as design goes, take a look at the Aero Commander. Every odd angle about that airplane was designed that way with single engine performance in mind.
The Q400 requires a noticeable amount of right rudder on takeoff, and since the airplane is 107ft long but only has a two axis autopilot, it also requires a fair bit of rudder pressure or trim every time you even think about moving the power levers, so we end up using the rudder trim knob about three billion times per flight.
The widgeon has this issue since it doesnt have water rudders. If you don't lead with the left, you'll not be going the direction you want.On the C-46, if you bring the engines up together, you may find yourself off to the races. I've not had the pleasure, but my immediate family and friends have, and you lead with the left throttle just a smidge.
I'll be doing it with AD when I buy a set for my airplane.Get your float rating yet? If not Don Lee up in TKA is awesome.
Here's one just a teensy bit bigger...I fly the small Diamond 40 which requires a good amount of right rudder at the appropriate times. I can only assume this to be true with the other small single engine trainers.
However, I started thinking about the bigger single engine airplanes that I get to see here and there.
What about the Pilatus's and the Caravan's and the TBM's. Do they also require a significant amount of the rudder on the takeoff roll and the like?
It could be a stupid question but I've yet to fly in a bigger single engine.
We use one unit to the right.The Saab took 1.5 units to the right for takeoff, set at the gate prior to departure.
I'll be in my bunk.Here's one just a teensy bit bigger...
When you jump into one of these to launch for the first time, just trim full rudder, then push the pedal to the floor, add power and hold on...
Do you have rudder pedal steering for the nose wheel?We use one unit to the right.
Nope. All tiller. But at 80 knots when the transfer of controls happens, the rudder is very effective.Do you have rudder pedal steering for the nose wheel?
The transfer of controls isn't at 0 knots?Nope. All tiller. But at 80 knots when the transfer of controls happens, the rudder is very effective.
Ya, probably next year. Unless you know of a good cheap set of 2000s with pacer rigging.You thinking about getting some edos?
Nope. I have the tops, and the captain has the bottoms until 80. At that point it becomes PF and PM.The transfer of controls isn't at 0 knots?
Is that because of something unique to the Saab? On the jet I flew, the captain would usually transfer the controls on the roll if it was a rolling takeoff or once lined up.Nope. I have the tops, and the captain has the bottoms until 80. At that point it becomes PF and PM.
I am not sure how other companies do it, so I dont know if it is a SAAB thing or company thing. @ctab5060X @jynxyjoeIs that because of something unique to the Saab? On the jet I flew, the captain would usually transfer the controls on the roll if it was a rolling takeoff or once lined up.
