Jonathan Jerome
Member
My dream job will be to work for delta as a 767-400 pilot, what are the chances of that happening without a military background.
They have before, and they will again.So next question... If regionals vanish and flying goes mainline, what options will people have to build experience in preparation for the mainline carriers? I can't see Delta or United hiring someone with 1500 hours.
(they've actually hired, at various times in their history, pilots with less time)
Who said that was a bad thing, precisely?I don't think it will get that bad.
It better not! I will be devastated. Are there talks of retiring the aircraft?Well. If you only have 63 hours, by the time you get to Delta, the 767-400 will be retired.
The website you're looking for is www.airliners.netIt better not! I will be devastated. Are there talks of retiring the aircraft?
Really now? Is that for delta only?The website you're looking for is www.airliners.net
What he was saying is aviation is typically a slow road. You have a LOT of ground to cover to head over to the Delta mothership. Even to be an FO you're talking close to a decade down the road. And who knows if they'll be needing 767 FOs when you get on.
Oh, and you need a degree completed in four years. If it took you five you're a worthless piece of rubber dog crap, in case you weren't aware.
Ha ha ha.You know, considering you're right there in Riverdale, GA which is darned near riddled (no pun intended) with airline pilots on layover nearby, you've got a treasure trove of information right under your nose.
Head down to the local airport.
Now how do you know where I live?You know, considering you're right there in Riverdale, GA which is darned near riddled (no pun intended) with airline pilots on layover nearby, you've got a treasure trove of information right under your nose.
I will from now on.Did you put the foil hat on before or after you posted this?![]()
Such a beautiful aircraft.Yep. Figure 10 years to even be in a position to get hired by Delta and then 8-10 years to be senior enough to hold a bid on it. It might still be around, but odds are it'll be replaced by either the A350 or 787 by then.
Dude, listen to yourself.Such a beautiful aircraft.
Sorry for sharing my thoughts.Dude, listen to yourself.
Member since Monday. 30 messages. 0 likes. You're not finished with college, 63 hours, about to enlist, and concerned with old 121 metal. Just relax and search old threads where other people had all the same thoughts and got all the same answers. If you have a unique question, then ask it. Otherwise...
