AirAsia A320 Possibly Missing
Now they are saying Captain was out of his seat dealing with some kind of technical malfunction.
http://www.nbcnews.com/storyline/ai...ain-left-seat-jet-lost-control-report-n297571
I'm not familiar with Airbus aircraft and their cockpits so take my opinion with a grain of salt. Everything that the pilots flying the aircraft that I am familiar with need to reach to deal with an emergency is within reach from their seats*, Is it possible the CA was trying to rerack a computer?
*Except for Hawkers, they have a panel of Buss fuses in the tail compt.
I would appreciate that. Perhaps the probes are somehow blocked from the slipstream from a high mach number on the nose and the wing isn't affected as much due to its size.
Okay, had a chance to talk to one of our guys. In summary, AOA vanes aren't designed to work in high mach scenarios, above .4 mach. Boeing did extensive testing and found that at altitude, they were unreliable due to compressability effects. When you get to high altitude and high AOA, the readings can be off by as much as 7 to 10 degrees.
In short, out has to do with mach.
And that's why you're just a pilot. :)
While the Feds don't agree with me in the slightest on removing airspeed(ya, that's a bit over the top), the way they fast tracked certification of AoA devices tends to lead me to believe they agree. Every cockpit should have AoA.
That's why NASA did testing on the F-15 with strain type AoA gauges. From the report they seem to work pretty well, but I'm unaware of it being put on anything.
Hell yes! My car is an Acura TL. I don't drive no stinkin 4 cylinders!
And the Altima is just a standard 2010 model 2.5S sedan. I think those all came with push to start buttons.
I've never quite understood how push button start has become a thing that people pay extra for. Is it really too much to have to stick a key in a hole and rotate it?
Well considering the amount of people who can't lock the passenger side door for me, yes. I suppose I should stop being first out of the car and do it myself. Everyone assumes all cars are keyless entry in 2015.
Nothing to re-rack in a 320.
I thought the same thing until I had a car with it. Its magic never to take your keys out of your pocket. When you exit your car, you touch a spot on the door handle and its locked. When you return, you grab the handle naturally and it unlocks. You sit down, press the brake pedal and hit start. I never have to reach for my keys, ever. It is awesome. Every car should have it.
