dustoff17
Still trying to reach the Top Shelf
Nothing good can follow these words......."I wonder what would happen if we did this..."
The NTSB expressed concern about the cockpit crew conducting an unauthorized experiment on the auto-throttle system ("...the flight engineer pulled the three N1 tachometer [circuit breakers]...") immediately before the engine exploded.
This has always been one of my favorites: http://en.wikipedia.org/wiki/TWA_Flight_841_(1979)
"The rumor was that 727 pilots were setting the trailing edge flaps (which were normally only deployed at low speeds along with leading edge slats) to two degrees during high altitude cruise, while at the same time pulling the circuit breaker for the slats so that they would not activate. This configuration was rumored to result in increased lift with no increase in drag, thus allowing more speed, higher elevation, or decreased fuel consumption."
Followed by a manual erasure of the CVR by the captain when they parked at the gate.
We have our "funky magical" procedures written down...mostly. The maintenance-directed (and yes, they are MX-directed) reset procedures are all in a manual that lives on my iPad.Ahh, Hoot Gibson.
The cautionary tale of "Cheeerdren, this is why we don't jack with the airplane"
Hell, I learned pretty quickly that a precocious FO that says, "Oh, have you seen this?" or "If they're warm, here, let me try this first" on the ground means that after contract maintenance leaves 45 minutes later, I'm going to be digging for a delay code.
Don't screw with it. Ah ah ah! I don't care about unwritten procedures days of yore.
Holy carp, how does a guy like that go on to fly the space shuttle?
That uh, that's not rumor. When the paint was worn off around the LE FLAP CONTROL VALVE circuit breaker on most airplanes, it ceased to be rumor.This has always been one of my favorites: http://en.wikipedia.org/wiki/TWA_Flight_841_(1979)
Two different "Hoot" Gibsons. You're confusing former TWA Captain Harvey "Hoot" Gibson with U.S. Navy Captain (ret.) Robert "Hoot" Gibson. I've actually flown with the latter on a shuttle training mission aboard the NASA G-2 shuttle trainer. Robert "Hoot" Gibson later flew for Southwest, but never for TWA. Great guy.
Dumb idea, dumb way to hack the matrix, and so on.
Stay in the matrix, cash that check, go home and play Xbox in your underwear.
You guys do know that Hoot and the crew was never disciplined by TWA or the FAA right?
Pretty sure he went back to TWA and retired at 60.
I used to use SkewT/LogP charts for short-term, local planning during thunderstorm season when I flew in and out of BOS in the 402. Good use for those.Or how to read a skew-t, a high altitude wx chart, the difference between vis and IR satellite images, etc. No one takes weather, and aviation wx is usually limited to reading a METAR, TAF and maybe an FA. Oh and we need to make sure you know the different types of fog and how they form.
Oceanic, high-altitude weather charts are hit or miss. In certain areas of the world, Southeast Asia among them, the best you'll get is a very general idea of what the weather should look like. I've flown through areas that showed all kinds of thunderstorm activity on the charts, and it was perfectly clear. Also, it's not uncommon to be surprised by areas of weather that weren't forecasted. Unlike the US, ATC is very little help in that regard, and often doesn't have radar (or you're CPDLC/HF with a radio operator, anyway). The myriad of accurate weather products we have over here really don't exist over there.
Anyway, we look at plenty of weather beyond simple METARs and TAFs (Area Forecasts aren't, well, a thing over there), but it's all pretty general.
The best thing you can do is learn to use the radar defensively in these cases.
Turbulence? Oh, right.... Passengers.This tool I use is sick accurate for turbulence and icing modeling:
https://itunes.apple.com/us/app/fsav-flight-situational-awareness/id855330848?mt=8
#freightisgreat #ohwaitsometimesIflypax
And icing.
