Do most airplanes do that? The SAAB has T/O inhibit mode. It inhibits most of the warnings except for a select few.
Refresh my memory, I understand that with no FLX temp set with thrust in FLX you get the caution telling you to go TOGA and if you don't then at 80 knots you get the RETARD callout, but in this case when you ignore all that and continue, just what exactly is the thrust set to? 75% N1? How does it decide what thrust to give in FLX with no temp set? Sorry I can't recall at the moment.
There are three other letters associated with the flex detent... Your answer lies there.
Must be nice. I've never had that.That is correct. Every jet I have flown has some sort of inhibit. The 737 is a bit on the stupid side, but the real boeings and airbuses have very similar logic where nothing but the worst stuff is show from 80 knots to a certain altitude.
The thrust not set- select TOGA caution in this flight's case comes at 60 knots, which is before takeoff inhibit takes effect. Above 80 knots, almost no cautions and only master warnings will show.
At 80 knots, due to the speed and the thrust levers being out of takeoff position/not in idle the plane says "RETARD RETARD" (directed at you personally, I assume) to indicate that it's not sure what is going on, so I'm going to go into the landing phase of the flight warning computer.
What I don't get is, if you're going to make these mistakes and continue on etc etc, how do you not pick a conservative as hell VR if you're just pulling one out of thin air.
Actually had a Lear 35 once that would flash the master warning light with no faults. Wrote that up a dozen times i think. @arkflyr might remember the lear, I think it was 39DK
Im not sure what youre saying, but im with you in spirit!
I'm saying if you lose airspeed data (not saying this is the case here) or, slightly lesser problematic, lose the V-speeds and don't remember what they are even close to, I would just let it fly itself off or rotate with around 2000-3000 feet remaining.
I know of a crew that had a significant disparity in airspeeds arise at about 120kts and they aborted. I strongly disagree with not taking that problem into the air; rotate before the end of the runway and pitch for the usual initial climb attitude.
If you abort, you're of course betting that your supposed unreliable airspeed data is reliable enough to tell you that you are indeed still below V1. But if it really is unreliable, then the speed may very well now be above V1.
I disagree on all but the shortest of runways.
Why? Ground speed readout. That'll give you a pretty good idea of how close to correct the airspeed is. If I'm on a long runway, I'm probably stopping. Short one...probably not.
But I really don't like the idea of going flying without knowing what your airspeed is. If it's obvious which one is wrong, that's one thing, but if you really don't know...
Reading it wrong.
I am sure @PeanuckleCRJ will correct me if I am wrong, but you don't get minor stuff come up on the ECAM during the takeoff phase.
That's a lot to do in a short time if you're at 120 knots and trying to stay on the runway.
Damn kids.
Always say it more eloquent that I could ever.
