Roger Roger
Bottom of the list
Plus it looks awesome.Yeah you can get at least 4 hours out of a 35.
"Gear up"
"Flaps up"
"Low fuel checklist"
Just because of the cost of the inspection? Or some other reason?
The cost is probably 2/3 the value of the airplane these days.Just because of the cost of the inspection? Or some other reason?
They're fast, cheap, and have a very large entry door.why are they (35's) used so extensively in air ambulance work?
I got pictures of the spar of my favorite 35 at airnet. Plane split it's 27k hours in S. Africa and Tampa, FL....not a lot of warm and fuzzies after seeing that.I saw a demate on a couple of high time 35s where the spar was dimpled due to rivets on fuselage stringers pressing into it during each pressurization cycle. Yikes...[emoji16]
I always found that the less I looked at them all torn apart the better off I felt... And Zap, my former employer had one of Walmart's 35s a high S/N, #662 if I remember right. On paper it should have been the nicest 35 I ever flew, in reality it was a POS. Only had 11 or 12K hours on it but all kinds of problems. We all did handstands when they finally got rid of it.I got pictures of the spar of my favorite 35 at airnet. Plane split it's 27k hours in S. Africa and Tampa, FL....not a lot of warm and fuzzies after seeing that.
Don't use a Beecher for EMS. Just don't....One of our local medevac operators is phasing out the 35s in favor of 2005 beechjets. They say the beechjet has shorter enough legs that alternates are going to be a problem on some of their normal trips that weren't an issue in the 35. So yeah...
Imagine if you need to turn the patient or do chest compressions if things unexpectedly go south.http://flightaware.com/live/flight/N363PJ/history?filterStart=2014-10-02&filterEnd=2014-10-04In a lear 35 air ambulance, I can understand 2 hours, but I try to comprehend how cramped it must be for the medical team with a critical patient, when they travel international, with multiple 3-4 hour legs.Imagine if you need to turn the patient or do chest compressions if things unexpectedly go south.
I forgot what goes on during a 12 year but they basically tear the plane apart. Among a multitude of other things I think they replace all of the control cables during a 12 year. The wing comes completely off... The first 12 year is costly, the second one (which the 55s are going though now) are very costly and parts are an issue. The next 12 year will park these planes. The 35s are going through their third 12 year And it just doesn't make sense to have a 150k cost or more to fix a 300k airplane.
It's better but not by much. The 55 is a "stand-up" cabin for most people.
Depending on the mission they can both be great airplanes but won't be viable after their next 12yr/12k inspection.
