Hacker15e
Who am I? Where are my pants?
It really just all depends
"It depends" is the most universally applicable phrase in all of aviation.
Computers are incredibly fast, accurate and stupid. (As my initial Brasilia instructor said: "Nobody can fly plus or minus one knot" - turns and looks at me - "...not even Dougie!" But the autopilot can.)Again, it really depends on the aircraft and the situation.
Hand-flying an Airbus during an engine failure can be doofus in many situations. Not all, of course.
Trying to use the automation during a visual approach when you're downwind abeam the numbers without an ILS is pretty doofus as well, but again, not in all situations. 400 feet, engine failure, turn on the autopilot, it will trim to the beta-target (the "ball") automatically and manage your speed until you hit acceleration altitude. Do that in a mad dog and it's going to be all sorts of hilarity.
Doing it in the Airbus product doesn't make you less of a man, the autopilot is just going to do a better job at optimal trim and will run laps around you with speed targets in most situations. Engine failure, autopilot on, it trims itself, continues climbing, you hit 1000. Press to level off, hit the "EXPED" button at "Green Dot". Easy peasy. Otherwise you're going from direct law mixing in with flight mode as you climb, hopefully trimming the right direction, transitioning from "stirring the soup" to light taps of the stick as flight mode blends in and telling the NFP (non-flying pilot), who already has his hands full, to engage certain modes for you.
I think the challenge with a lot of us is we're looking for a universal answer where there is none. It really just all depends.
Analyze the situation, open your toolbox, use the best tool for the job.
There is no universal answer.
Careful, ATN will call you an yeager needing to stroke your ego for turning it off! That's when panda gets mad.
I can't believe they don't let you touch the tiller... That sucks! We use the expedite button for high Grid MORA mountainous departures, too. Works great, lasts long time.![]()
Yet again, here's the cat, that skin has to come off!
It's true, dude.
Difference is, at this point anyhow, humans can learn. The closest thing a computer can do is some form of pre-programmed learning algorithm.Computers are dumb. They are programmed by humans... Think Therac-25.
http://courses.cs.vt.edu/professionalism/Therac_25/Therac_1.html
Stupid humans there too, incidentally.Computers are dumb. They are programmed by humans... Think Therac-25.
Me: "... Wait... did the airspeed just select itself to 40knts? How did that happen?"Stupid humans there too, incidentally.
"Oh, ze software, she cannot be wrong!"
-ZAP-
"No, no, it is not possible!"
-ZAP-
"Oh. Uh. Well. If you press SET right when that counter rolls over...uh...um...yeah, it turns out that is possible."
CA: "Oh roll it back quick, it's a known issue."
Me: "Que??"
CA: "Hey bud you're going to miss AMYLU"
FO: "Wait, I don't see it, the line is before AMYLU"
CA: "It's doing that thing, you'll be at 16k right now with this descent rate."
FO: "Damn you're right, it caught me again *speedbrakes*"
Me: "I don't understand, is the computer misprogramed?"
CA: "No, on these 190's sometimes the computer doesn't computer the descent correctly and even though the banana is on AMYLU you'll miss it by 5-8 thousand feet. It's a known issue, you just have to do the math in your head every descent and make sure it makes sense."
FO: "Yeah my goofup, the math looked right to me until Longhorn here told me"
Me: "Longhorn?"
CA: "Yeah I'm a big football fan and I live in Texas, you couldn't tell from the temp I keep the cockpit?"
*still missed AMYLU with brakes full out*
what would the NTSB know...it's not regulatory. Silly NTSB recommending that pilots keep up all of their skills...I'll just leave a little something from the NTSB be report on Asiana Flight 214. Take not on the US regulatory change supporting pilots regularly performing manual flight so their airplane handling skills do not degrade.
No, the computer is always smarter than you. You just didn't realize it because you're a show off.ERfly said:Sometimes, the computers ain't that smart.
That is why there's that big red button on the yoke (sidestick?).Sometimes, the computers ain't that smart.
apparently that's a panic button.That is why there's that big red button on the yoke (sidestick?).
It's usually accompanied with "What the (bleep) is this (bleep) thing doing now?"apparently that's a panic button.
lolIt's usually accompanied with "What the (bleep) is this (bleep) thing doing now?"
"Oh, it's doing it again"I've been on the Airbus almost 2 years. It's gone to "Yeah, it does that sometimes."
CAMI
