I could get at least 50% of crews into that corner point. They only had to not look at their airspeed for about 8 seconds to get in the hole.
8 seconds is a long time to not be scanning your airspeed during an approach. I mean, I probably shouldn't talk, I'm not a Boeing pilot, but why the hell aren't guys monitoring their airspeed on approach? That's like, I dunno, private pilot stuff! And OK, I understand that in the simulator, you can task saturate guys and get them to fixate until they auger in or whatever, but let's be serious, that's why we have the stabilized approach concept, that's why we have specific "gates" we fly through, as a pilot descends below 500' AGL, he or she should be thinking, "OK, I'm lined up on the proper runway, I'm properly configured, I'm
stabilized on-speed, gear's down, sink-rate's good, I'm cleared to land." Whether or not there are callouts for this sort of thing, this is what a pilot
should be thinking. It's really not that much to ask, it's only 6 things to think about. Here if that's too hard, I've even made a mnemonic for this:
Super C
Speed is stable at ref
Undercarriage is down and locked
Proper Configuration for landing
Excessive Sink Rate?
Right Runway is Right there
Cleared to land
At 1000fpm (which is probably an excessive sink rate on final in a Boeing, I don't know), and assuming the latest you can abort a landing is 200' AGL without hitting the ground (again I don't know), that gives you 18 seconds to figure out that something wasn't right. On the flip side, if your sink rate is less because you're dragging it in 30 kts under Vref, it should give you plenty of time to go, "uhhh, something's not right here, time to go around."
I dunno about this accident, I mean, I'm not a boeing pilot, and this most certainly
could happen to me if I have a bad day, but blaming this on the design of the airplane or on the training department seems to be no-bueno for me. If I'm approaching the ground, and my speed or sink rate aren't correct, I go around. A go-around should be a conditioned response, like windshear, or a terrain alert.
