z987k
So over 15 years there has been a $12,000 paycut. Neat.34k starting pay starts in November. So 2833/mo.
I find it hard to believe that any pay in any of aviation has kept up with inflation including low tier jobs like CFI's.
I was thinking the same thing....even at the majors. They haven't even gotten back to pre 9-11 wages yet.
From what they are saying in training now, the pilots that AMF are recruiting now are getting worse and worse. The failure rate for some of the classes has been ridiculously high. It is hard to believe that they will continue to find good pilots as the number of corporate and 121 airline job vacancies continue to increase - even with the recent pay increase.
It might have something to do with how aweful that training department is. Where they refuse to teach anything, you just show up to get evaluated.From what they are saying in training now, the pilots that AMF are recruiting now are getting worse and worse. The failure rate for some of the classes has been ridiculously high. It is hard to believe that they will continue to find good pilots as the number of corporate and 121 airline job vacancies continue to increase - even with the recent pay increase.
@Inverted AMEN! - I talked to the guys in the EMB-120. 4-5 days of ground, 5 sim sessions, then a check ride. I believe the last class had a 50% pass rate.
Well, it is a setup for failure in some cases. Any initial in a new airplane is 2-6 weeks long. My XLS type was 17 days, Lear 55 was 14. 121 training is a month at least. This is after you have a week of indoc (at least) learning company procedures. AMF indoc is a week of class which has little to do with the airplane. Then you are thrown into a week of cardboard flows and sims in an airplane that you have never flown, and is made more complex than it needs to be with flows, callouts and procedures. To top it all off, you have to do it by yourself. It is a high bar to achieve.
No initial training ANYWHERE are you expected to know the limitations, flows, callouts and procedures before showing up. That is the literal essence of a training dept. AMF isn't in the business of training. So it makes total sense that if you set the expectation of new hires showing up with the knowledge and skill to pass a 135 checkride and oral, a bunch of people won't be able to make that happen.
.... As a first officer? The duties are not that of a captain.
They really do make the entry level airplanes more complicated than they need to be but the transition from Seminole to PA31 or 99 still requires way less learning than the transition to an RJ or small jet would - hence the shorter time. Day 1 to PIC checkride runs about 4-5 weeks as well so only a week or two less than a 121 program.
Limitations, flows, callouts and procedures are all learned by rote memorization at first then correlated into training later on. I don't see why it matters when someone memorizes something in the training process and I don't think that adding an extra week in a hotel after indoc is over so that people can learn their VSpeeds makes a lot of sense either. If someone can't memorize numbers and flows on their own, the program doesn't have the time or manpower to hand hold and spoon feed which means the trainee falls behind and eventually out.
