I'm familiar with that article... I recall reading it long ago and agreeing with it. That said, sometimes I think we take the checklist thing too far in small airplanes. There simply aren't that many 'killer items' in a single-engine Cessna, and most of them are highly conditional. For example, taking off from a short runway while "at" max gross weight on a hot day can legitimately make the flap setting a 'killer item', but reading 'flaps 10-15°' off a checklist doesn't really solve that problem when 15° gets you off the ground high enough to turn and 10° puts you in the trees.
It's possible that the 207 is the simplest airplane ever made, because I simply can't think of anything that a checklist would catch. Everything is cued by context. It's like numbers... I really don't care what the 'numbers' are for the 207, because it tells me exactly what it needs.
As airplanes become more complex or less familiar, of course, the value of flows backed by a (airline style, not GA style) written checklist does increase dramatically, especially given abnormal / emergency procedures. But the principal of context/flows for simple airplanes is similar to the concept that as long as gear is a drag device, you won't forget it. I can't say I've ever forgotten to put the flaps down in a flap-equipped airplane, for example.
I dunno. I just don't know what there is to read off a checklist in a 172 during non-instructional flying. However, I generally have a great deal of respect for your thought process and expertise, and am interested in understanding your (personal) rationale rather than trying to make a case against your process.
-Fox
(I also realize that, historically, I've found myself fundamentally differing with what often seems to be the prevailing viewpoint on many subjects. Sometimes it's due to lack of shared context, sometimes it's due to fundamental differences in perception / interpretation / execution, and sometimes it's due to lack of experience in things that later alter my viewpoint... though I try to stay open enough to the latter to preclude it as a strong source of influence, it's nearly impossible to do so with perfect objectivity.)
By all means!
I learned how to fly with the Cessna "book" checklist in my lap most of the time at the insistence of various and sundry CFIs. A lousy checklist can be worse than no checklist, and letting the lawyers write the checklists has resulted in a bunch of GA pilots having bad, or nonexistent, checklist habits. But my checklist isn't lousy. Checklist use is a really good habit to be in, I think, regardless of the equipment—flow-and-verify means that you're really paying attention. (Aperture was heavy on checklist discipline as well, even if they used the lousy Cessna checklist.)
You're spot on about single engine Cessna airplanes. Each phase of flight really only needs 2-4 items to be done. But it behooves me to write them down and do them the same way EVERY TIME so that I can trap my own mistakes.
Here are some reasons:
(1) I was flying a lot of different, but similar airplanes at the time. The operator wanted them all flown slightly differently. You wouldn't hurt much if you goofed various things up, but it behooved me to not goof anyway.
(1a) It's a good habit to be in anyway. Everyone flying anything bigger than a Seminole is going to require you to use a checklist of some sort.
(2) The operator wanted us to use a checklist. They didn't say Cessna's, so I wrote my own, airline-style.
(3) Authoring one made me delve into the books more.
(4) Fast forward to now: I don't fly our Twin Bonanza that often; it's just complex enough that a set of flows, backed by a checklist really are required especially given that my flight experience in it is usually 5 hours or so every 90 days.
You've got good points about e.g. flap settings. My 172/182 et al. checklist says "FLAPS -- (___)" — more so that you'll think about it. But it was more to build habits then. (Now, of course, I depend on it in the TwinBo.)
Incidentally, you'll hear me mumble "Brakes, trim, flaps, autofeather, [condition levers] max, MAP clear" before every takeoff in the Brasilia. Written nowhere, but those are the things that WILL kill/otherwise hurt you with a quickness in that airplane. And since the FLAP gauge and gear handle/lights are right in front of me on the Brasilia, I glance at them crossing the fence, too.
("Haven't tried it...yet")
