Roger Roger
I am le tired
Specifically 135 in a single pilot aircraft. Count towards total time/cross country time/etc? Or just make a separate column for 135 flight checks given?
That was my thought.Aren't you technically PIC while conducting IOE? I would log it as a normal flight with you as PIC, maybe putting in notes that you were conducting IOE. Logbooks are your personal record so you can do whatever you wish, I just always try to remember that if someone was looking at it in an interview I should be able to explain it. In your case the IOE check airman is the PIC.
My thought is it has to count at least as total time, as I am a required crewmember during IOE. I have been logging it as dual given, which I'm fairly certain is NOT directly applicable, but works as a placeholder.And here I thought there were no good unanswered logging questions anymore. I'm not aware of a good answer to this one. The three closest 61.51 "boxes" are
• 61.51(e)(3) which allows instruction given to be logged as PIC time, but the reg specifically says it's for a "certified flight instructor" not the more generic "authorized instructor."
• 61.51(e)(1)(iii), acting as PIC in a operation that the FAA requires have more than one pilot; and
• 61.51(e)(2), and ATP acting as PIC in a operation that the FAA requires the PIC to have an ATP.
But I don't know enough about your Part 135 IOE program so I'm not sure if any of those are really applicable to your situation. It's certainly possible your situation falls through one of the weird cracks in the logging rules, like the instrument rated pilot who acts as PIC but allows his non-instrument rated friend to be the sole manipulator under IFR (the PIC can't legitimately log FAA PIC time).
I kinda like @Dan208B 's answer, although I can't agree with the "Logbooks are your personal record so you can do whatever you wish" part.
It hasn't changed at all. The problem is that from an FAR standpoint, just as there are situations where one who is not acting as PIC is entitled to log PIC time, there are situations in which one who is acting as PIC can't log it as such.If your OE is like 121, you, as the instructor, are signing for the aircraft. As far as I'm concerned, that meets the definition of PIC. Unless the FAR changed, there was a definition that the designated PIC for the flight was the PIC.
I don't disagree with any of what you say in this post. I have a knee-jerk response to the simple statement that "it's your logbook" because it's often interpreted by people as meaning there are no consequences to mis-logging something. It's kind og like saying you can put anything you want in "your" business accounting records. The IRS might have something to say about listing your family vacation as a business expense because you called into the office twice.@MidlifeFlyer I don't mean to sound too relaxed with it. There are absolutely regulations about "loggability" such as some of the ones you listed. However if you want to add or remove columns or whatever you want it doesn't really matter since it is your own record. But you do need to be able to show things like currency and have a legal, accurate record if you are job seeking, applying for an additional rating, or have some sort of incident that might involve looking into your logs. I have to say that recently I've come across more than one person that expressed unhappiness with their lack of understanding of logbooks and entries and that they were never taught anything about it other than what their instructor wrote in the logs. This is unacceptable, it's an instructor's responsibility to clearly explain it.
One would think. But that's why it's had to come up with a solid answer without knowing more about the operation. If the check pilot is indeed a required crewmember during an IOE, you would have flight time of some sort, either PIC or SIC. But I think it's been relatively clear for a while that there must be some 61.51 box to fit into in order to log any flight time at all.My thought is it has to count at least as total time, as I am a required crewmember during IOE. I have been logging it as dual given, which I'm fairly certain is NOT directly applicable, but works as a placeholder.
What an airline is looking for or interested in counting as experience is a separate question.
How can one be "sole manipulator" in an aircraft requiring two pilots?
Wow, you mean when you fly a 2 pilot operation, both of you have your hands on the flight controls (or have primary autopilot duties) all the time? Interesting. Even when I teach I don't do that. Seems to be a silly duplication of effort when there are other flight management tasks that CRM would suggest be divided between the pilots.How can one be "sole manipulator" in an aircraft requiring two pilots?
The legality versus reality choo-choo train is frequently delayed at Absurdville Station.Also, as you love your tittles...
It says "sole manipulator of the controls", not flight controls as you put in your post.
There are lots of controls a non-flying pilot manipulates on a muilti-pilot airplane. One pilot typically controls flight path with the yoke, rudder pedals and throttles, or the autopilot. The other typically moves the gear control, flap control, pack control, apu control.
You are correct. My bad.Also, as you love your tittles...
Here is what 135.244 has to say about it, in case you hadn't looked it up yet.One would think. But that's why it's had to come up with a solid answer without knowing more about the operation. If the check pilot is indeed a required crewmember during an IOE, you would have flight time of some sort, either PIC or SIC. But I think it's been relatively clear for a while that there must be some 61.51 box to fit into in order to log any flight time at all.
Yeah, I read it. That's the problem. It doesn't completely solve the FAA logging issue for me.Here is what 135.244 has to say about it, in case you hadn't looked it up yet.
