Friends don't let friends use kneeboards.So for those of you who use an ipad in the airplane, what do you use for a case or kneeboard or anything? I have an ipad3 and am going to start using it and wondered what y'all could recommend in that department. Thanks
I just set it in my lap, easy to pick up when I want.Friends don't let friends use kneeboards.
I tried that but it seemed like it would go sliding off my lap at the worst times and end up buried under the rudder pedals. I like having it mounted but mine is a mini, a full size might be too in the way if it's not in your lapI just set it in my lap, easy to pick up when I want.
That is exactly what happened to my Android tablet. Now, I have to replace the screen.I tried that but it seemed like it would go sliding off my lap at the worst times and end up buried under the rudder pedals. I like having it mounted but mine is a mini, a full size might be too in the way if it's not in your lap
Why? Curious mostly. When I am jump piloting it holds everything I need and the Velcro strap holds my headset. Pretty compact package IMO.Friends don't let friends use kneeboards.
Just being a dick. I used to carry one through my last CFI flight. It was mostly used to pretend to write notes to make students think they were doing something wrong. I was a horrible CFI.Why? Curious mostly. When I am jump piloting it holds everything I need and the Velcro strap holds my headset. Pretty compact package IMO.
Y'all use iPads over there?Although to don't use one for work I'm required to have a strap. Take a look at this product.
MyClip Thigh/Kneeboard for iPad and iPad 2 by Unknown http://www.amazon.com/dp/B0054ZVF9G/ref=cm_sw_r_udp_awd_3o5ntb0D9VGVC
