fholbert
I understand what you are saying....but you still don't get it.
I pretty much have you figured out.
Brent you're wrong. There is a "standby" switch position on the transponder, just like almost all other Boeing aircraft. When the switch is in standby nothing gets transmitted. Power is still being applied to the actual transponder and the con
trol unit on the panel so you can set a new beacon code, but there is no transmitting going on.
Why waste money on three transponders?So let me get this straight....on the 777 and all Boeing aircraft there is no triple redundancy?
What does that have to so with anything? Hell, the podunk CRJ I fly has 3 hydraulic systems. Guess what, they don't do anything with the engines shut down and the pumps in the off position. Or are they like our two transponders? Can't turn them off either?So let me get this straight....on the 777 and all Boeing aircraft there is no triple redundancy?
CNN yesterday repeatedly broadcast different live segments from inside a 777 simulator with pilot. He showed where the transponder was
located on the center pedestal, and how it could be turned off with a switch on the unit.
Did I dream that?
CNN yesterday repeatedly broadcast different live segments from inside a 777 simulator with pilot. He showed where the transponder was located on the center pedestal, and how it could be turned off with a switch on the unit.
Did I dream that?
http://www.buzzfeed.com/dorsey/cnn-shows-potential-hijackers-how-to-turn-off-a-boeing-777s?s=mobile
So this sums up your feeble attempt at mockery?
Are we talking about transponders or ACARS? Or the separate engine trend monitoring transmitters? The transponders, it appears, seem easy to turn to stby.
@typhoonpilot, can you help us put this 777 transponder issue to rest?
Interesting how when 777s, or any plane, land at SFO, the ground radar I have up here in the ramp tower shows the planes ID/squak until about the time the plane exits the runway, then it magically disappears becoming an anonymous blob the rest of the way to the gate. It's almost like the pilots run a checklist and put it in standby mode or something.
Please don't, I'm really enjoying it. Like driving past a car accident, can't help but look.
BoeingWhy. Both US and Canada had passengers on the flight.
Boeing
Fair pointYou're thinking none of the parts are made in Canada?
