JOEFRIDAY2
I still am one of those that see no evidence that this plane has crashed.
If the plane had crashed the ELT's would have gone off.
Joe
Joe
Not if it was underwater.
Still, it does Iran no good to steal one. Whats one 777 going to do for them? They can't use it without it being seen that they have it.
And the stolen passport thing.....I said it on page 1 of this thread, that's nothing more than a petty theft and fraud right now, as there is nothing to link that event to any foul play.
ACARS DOWNLOADS:-
.N936UA 5Z0 3617 UA2251
/25 SFOSAN -16 0946 725 279 290
0804 000 608 0892 2495 00 90 000 42 0200
0804 000 598 0886 2510 00 50 000 44
EDITED VERSION:-
REG# MSG TYPE MIN/SEC FLT#
.N936UA 5Z0 36 17 UA2251
DATE FR TO TMP GRWT M. IAS FL
N1 EGT N2 FF OT OP ?
-----------------------------------------------------------[10/06/1997 18:22]
ACARS mode: 2 Aircraft reg: .N778UA
Message label: H1 Block id: 6 Msg. no: D42A
Flight id: UA0947
Message content:-
#DFB E23C03 778 0947 EHAMKIAD 061097 1330 ER
189 3 841 841 2744 2746 -580 -585 36999 37004 472764
7844 7590 1198 1198 017949681111130213000000000 0
63.7186 -25.0401 -1054 06-1048 0002 0015 06700 13
0 46734 47230 23814 23118 32 40 375196803500379200 17100
61500 61900 777007 777052 3441 3441292)004
10 0) 10 04015016 0) 14 29 34 0) 0)36438-3895014
598 598 6 8825 8755 878 874 4340 4286 373 414 556 589
11 64 67 78 8137 8377 115 109 00 03 00 21 -08
-309-309-310-310-307-238-238-237-237-306-308-308-309-310 009
009-381-402-025 001 000106105004016 000 000 000 000 0050
EDITED VERSION:-
Flight id: UA0947
Message content:-
ENROUTE
MSG TYPE REG# FLT# FR TO DATE TIME RECORDED
#DFB E23C03 778 0947 EHAMKIAD 06 10 97 1330 ER
MACH FOB TMP FL GR/WT
FF EPR
7844 7590 1198 1198 0179 49681111 1302 1300 0000000 0
LAT LON
ENGINE #'S
FL
ALL THE FOLLOWING IS UNKNOWN!!!!!
I talked to Hollywood tonight and they're already working on a screenplay. Tom Hanks should be able to do Malaysian.Oh those crazy Somali pirates!
"Look at me. I am the captain"
Not every other country is as scared of their own shadow like the US.The German magazine Stern (online edition) is reporting that on a previous flight with same co-pilot (and maybe pilot) two attractive young ladies were invited into the cockpit by the flight crew. The girls said they spent most of the flight on the flight deck, including take off and landing, and they showed a variety of photos of themselves in the cockpit, wearing the pilots' hats, and otherwise enjoying themselves..........
http://www.stern.de/panorama/vermis...beobachtet-feuerball-vor-vietnam-2095979.html
The passage regarding the girls and co-pilot is at the end of the article.
Was going to write the same thing.After seeing who wrote the article, it will turn out to be true. The gentleman who writes for aviation for the WSJ is the best aviation reporter in the world.
Would that engine data show whether it was spoiled down for landing or any other thrust changes?
Joe
Then why would the transponder be turned off?I'm still with the idea that the aircraft was instructed to turn onto a heading of 58 degrees by the auto pilot (as expected by the airway, and as performed by the preceding aircraft) and after that it continued to fly that heading until it ran out of fuel (or something else brought the plane down) because the crew were incapacitated and could not program then auto pilot to perform the next left turn on the airway (as expected and performed by the preceding aircraft) and that ADS-B data (and maybe more) transmission ability lost due to whatever incapacitated the crew.
Both the "power panel overheat" mentioned before and a minor hull breach at the SATCOM antenna adapter plate allowing slow decompression - either of these could explain why the flight continued for more than 4 hours (if it did) undetected and an incapacitated crew and without relaying data or changing course .
( Remember that a 16-inch crack under the 3-bay SATCOM antenna adapter plate had already been discovered on another B777)
Or is it just wishful thinking that this was an accident and not deliberate.
My only issue with this, do modern airliners not pre-load their flight plan route on departure, ammended in flight as required?I'm still with the idea that the aircraft was instructed to turn onto a heading of 58 degrees by the auto pilot (as expected by the airway, and as performed by the preceding aircraft) and after that it continued to fly that heading until it ran out of fuel (or something else brought the plane down) because the crew were incapacitated and could not program then auto pilot to perform the next left turn on the airway (as expected and performed by the preceding aircraft) and that ADS-B data (and maybe more) transmission ability lost due to whatever incapacitated the crew.
You would definitely think it would send information if it flamed out due to lack of fuelAccording to that (very dated) link there are takeoff and climb reports in addition to the cruise updates it sends, but I'm not sure about landing.
The Asiana accident in SFO was on the net I hours though the final report hasn't been presented we basically know what happened.
