Canadair Crash at ASE / Aspen Eagle, Colorado
Be curious to know what their actual ground speed was, it looked like an air show pass.
Any good discussions to have on the merits and drawbacks of each?
The gotcha in a Challenger is when one of the prox switches or sensors fails (squat switches in simple terms). The airplane will always think it's on the ground. Symptoms include the gear safety latch failing to disengage, deployment of ground spoilers when thrust levers are moved to idle, and deployment of ground spoilers in conjunction with application of flight spoilers. The latter two only occur if the crew fails to observe the WOW I/P FAIL or WOW O/P FAIL light and take the appropriate action of turning the ground spoiler switch to the OFF position.
Aside from that, and bouncing like an over inflated basketball as in this case, they work pretty well.
Gee @TFaudree_ERAU you seem to know a whole lot about this subject. Glad to have that resource on JC, then again my wife is also pretty familiar with the system as well thanks to your "tutelage".
Embedded media from this media site is no longer available
wait til "camera 5". it bounces 30 feet back into the air!
Looks like a classic PIO scenario. Some airplanes are much more prone to it than others. For example, the Grob 103 has a history of doing this when forcing it onto the runway at too high an airspeed. I have seen one land in a tailwind, pushed on to the runway, and bounce all the way down due to overcorrections. Luckily, the impacts weren't hard enough to damage the airplane. The pilot finally set the spoilers to an open position, held a landing pitch attitude, and settled to the runway once the speed bled off enough.
Unfortunately in this case, it looked like the nose down input at the top of the "cycle" was too drastic to recover from.
