Screaming_Emu
60 degrees of bank in the pattern? Kick ass, I'll try that tomorrow between LGA and IAD.
Many folks here are guilty of this. Numerous threads attest and the subsequent internet CFIing ensues.it is tough to convince students to leave the "warm, chewy center" of the operating environment of their previous training programs and explore the new areas of aircraft performance that successive programs explore. Students get artificial limits hard wired into their minds (rule of primacy, anyone?)
As usual, if you are flying an fighter like an airliner, or an airliner like a like single engine GA aircraft, you are wrong.
and roll models
Ahhh, aerobatics instruction, then.
And ALL of my students did spin training before I signed them off to solo, so it's not like they didn't get experience with cross controlled stalls or high bank angles (while doing steep turns). But we did it with altitude to spare. We did this partially for my comfort, because I wasn't interested in trying to rescue us while low to the ground more than I needed to, and because I didn't want to set a bad example for my students, giving them the impression that it was ok for them to perform 60 degree banks low to the ground when there was no need to do so (and before somebody cites it, the example that Russ gave isn't applicable to the instruction that I gave, as I've never flown a glider in my life).
For the comfort of the boxes.Remember under 135, 121 and the standards for their check rides(ATP to iirc), going past 30 degrees is a fail.
exception I can think of - a turn back to the departure runway engine-out. Really must be taught as 45 degrees exactly. Power off 180's are another example. If your pattern altitude is 800 AGL or lower, there are a lot of aircraft that need more than 30 degrees of bank to make a runway.
I don't know any instructors that do anything else.
What you do on the line flying boxes I could care less about. 90 degree turns if you feel like it. For the checkride however, 30 degrees is the limit.For the comfort of the boxes.
We brief a hard turn back altitude of 600 AGL. I also have a student attempt one before they solo.
I never taught my students to turn back to the runway if they lost an engine in a single. In fact I told them to forget the idea entirely and just to land straight ahead.
Our check airmen train (and check) a return to the runway from 1000 AGL. As long as you remember to feather the prop, the greatest danger is overshooting.
I'd trust an astute professional
Herein lies the whole reason why I posted this article. Why did you teach that?I never taught my students to turn back to the runway if they lost an engine in a single. In fact I told them to forget the idea entirely and just to land straight ahead.
and (in my humblest of opinions) sole purpose as a CFI is to teach said student the ability to make decisions
Every situation is different, and (in my humblest of opinions) sole purpose as a CFI is to teach said student the ability to make decisions.
This article's main point is instructors teach students things, simply "because" and not the "so-what" behind it.
