Houston
AFAIK, the only records the FAA has concerning 141 stage checks are for the ones that grant a certificate or rating, and if an employer wanted to find records about something like a pre-solo check, they'd either need to get a copy of the relevant TCO from the school and go through the logbook in detail, or get the training records from the flight school, which is very unlikely due to the liability it exposes the flight school to.
I was a check instructor at a 141 school: Failing a 141 stage check isn't reported to the FAA, even if the 141 school has self-examining authority and the stage check was your final check (which would result in the issuance of your pilot's certificate.) It is kept on file in your required 141 documents as a student for a certain period of time and could be audited by the FAA, but even if it is it isn't like the FAA will then add it to their database. I always thought that this was kind of a sucky double standard for part 91 and part 141.
But I would say that it wasn't uncommon to have a student not quite ready for a particular stage check -- should he indicate that he failed that "training event"? I wouldn't think so, we just trained some more. Even if you're part 91 you have personal, informal "stage checks" that you do as an instructor -- or at least I did when I thought the student was ready for solo, getting close to checkride, etc. The only stage check I would consider a failure is the last one at a school with self-examining authority.
I'm sorry, but I'm getting lost in your wording. I think what you're trying to say is that the FAA provides everything it has in the report, but that not everything that is done in training / testing / checking is reported by the carrier to the FAA. Is that a correct interpretation of your statement?
Here is what AC 120-68F Paragraph 1-7a says in regards to what the FAA expects the operator to request and what the FAA provides:
I haven't read the thread, but if you sign a statement on your app certifying it as true and it's not, it is grounds for termination.
Upon reviewing the play, I probably shouldn't have quoted you directly with that answer.I don't see how that answer, quoting my words, relates to what I wrote?
Amazing, and other expressions of disbelief.I was a check instructor at a 141 school: Failing a 141 stage check isn't reported to the FAA, even if the 141 school has self-examining authority and the stage check was your final check (which would result in the issuance of your pilot's certificate.) It is kept on file in your required 141 documents as a student for a certain period of time and could be audited by the FAA, but even if it is it isn't like the FAA will then add it to their database. I always thought that this was kind of a sucky double standard for part 91 and part 141.
I'm merely urging caution (and urging that one err on the side of disclosure, because there's nothing more awkward than "grab your stuff and follow me") in what you choose not to disclose to a prospective employer, is all.
"It's not a failure if nobody finds out about it" is, to me, a bit of a slippery slope.
I couldn't agree more. Mark Twain said it well:
"If you tell the truth, you don't have to remember anything."
It's important to note that some airlines (if not all) will check your logbook for verification of the dates of your previous stage checks. If they catch on through your logbook that you have lied on your application, you will be shown swiftly the path to the nearest exist. I suppose that one could forge his/her logbook in order to get around that procedure, but in that case you would have to live with the fear that one day you may be caught, and the results will not be pretty if that should happen.
Terrible advice!
First of all, disclose everything you can, be honest, up front, and own mistakes.
Multiple failures in 141 or 142 mean we have bigger problems than just worrying about disclosing a failed checkride.
I hope none of your candidates have had to go home with their tails between their legs when they got pulled out of class because of something the airline found out.
Perhaps you misunderstood my advice, I'd never recommend a pilot to hide or lie about anything. Honesty is always the best policy. I take a pilot's honesty as an assumption. This may lead to disqualification for one picky airline interview but that's nothing compared to the dire consequences pilots can find themselves in if accused of dishonesty.
Report that stuff I say! I don't know a single "bad pilot" from UND that wasn't able to get a job, even the ones with bad attitudes about it.
I'd rather be written off for anything under the sun over being a liar. Liars are scum. You'll get caught someday anyways.
