I once let a student talk me into doing a night x/c to sedona az. When I realized that I would likely die if I lost the engine (being night in very rough terrain). At that point in my career I decided that if I can't glide to safety, and I'm in a single engine plane, then I will not go there. I will not gamble my life that the engine will keep running. My suggestion: don't go there any more.
For example, I will not do a night x/c over any rough terrain including forests, mountains etc. I was not being technical, just saying in general, I will look for simple ways to mitigate risks. I will find a highway to follow rather than go direct. Stuff like that. But then again, I think it is smart to just go in the day if it is possible, or go in a twin if possible, and ensure adequate single engine performance based on current conditions. If none of these are possible, then I reschedule. As before, I choose not to let my life depend on an engine that may quit at any time. If you feel differently, great. I do not.How about flying over endless forest at night with no moon out? What do you mean by glide to "safety"? From what I've seen, there is an elevated risk flying at night single engine, and you just need to do the best with what you have.
Nyet. First of all, I'm a great swimmer. I'm in shape and haven't lost my competitive edge. I am consigned to the fact I will likely lose one or two passengers. That sucks terribly but a captain must accept the inevitable even though they exhaust themselves in rescue efforts. Second, the lake is a known whereas the tree present several unknowns chiefly which are fallen out of the trees in a spine crushing descent and impact with rocky terrain. Thirdly, (closely aligned with my 2nd point) you don't know how far you'll drop and into what terrain. In the given scenario it is likely you will softly drop from the trees only to arrive to sudden impact in rocky terrain. Still, the g load of dropping will likely cause severe spine injuries. In that case the likelihood you will survive post-crash exposure is low.You're pretty much going to die.
The lake is a bad bet. Chances are the plane will flip and unless you've got dunker training, especially with the cold water, you probably won't survive.
That said, most light singles, you can stall out into a tree and walk away with nothing more than a broken nose if you are lucky.
Yes, it would matter. How much energy you carry into the crash is key. You can research which of the types you mentioned have the higher stall speed for a given weight, etc. The 'van being high wing may be more survivable but again you should research that.Would it make any difference on the TYPE of single engine? Meaning, if you were flying a PC12, TBM or Caravan....would that make any difference in your choice of landing spot? I mean either way, your odds of losing the engine in one of those is dramatically less than a piston single but they are all much heavier than a 172. That's what I'm getting at I guess.
You can glide about 2nm for every 1000 feet altitude loss in the PC-12. Flying it around west Texas and eastern New Mexico I am very rarely out of glide range of an airport. Taking it into Eagle or Telluride might be a little scarier, but I wouldn't mind it either.Would it make any difference on the TYPE of single engine? Meaning, if you were flying a PC12, TBM or Caravan....would that make any difference in your choice of landing spot? I mean either way, your odds of losing the engine in one of those is dramatically less than a piston single but they are all much heavier than a 172. That's what I'm getting at I guess.
I can't swim...so...trees it is. I think about this often as I fly over the SF bay and the Pacific Ocean. There are times in most flights where I realize if the engine quits I'm going to drown. Good times.
Interesting video and interview with a guy who survived a dip in a Cessna 150 and teaches water egress was posted to ASF.
http://www.aopa.org/asf/rps/rps_underwaterescape/
