Awe. No love. New weights and rigging procedures to be released shortly. Hopefully only stuck below 340 till July.Its a crappy Hawker... Nuff said.
Oh come on now. The newer 800XPs and higher are actually 370-410 airplanes. You're only doing .74-.76, but you're still up there...
Regarding the issue at hand; from what I've heard, it's an aileron rigging problem. Cable tensions get slack, and with the reduced pressure over the tips of the ailerons due to winglet design, you get the flutter.
Flutter is no joke....
Have you ever seen the videos on Youtube of the Cirrus pilot who mounts his GoPro (or similar) camera to the top of the actual rudder?
It's difficult to tell, but it looks like it's installed behind the counterweight and possibly behind the attachment point.
Installation of the composite blended winglets requires removal of a section of the Hawker’s prominent aileron horn balance and the addition of leading-edge weights for aileron balance. Certification is expected next summer. Installed price is expected to cost about $350,000, significantly less than the $520,000 price for the GII winglet installation.
In a Service Bulletin issued May 3, winglet manufacturer Aviation Partners (API) instructed operators with winglet-equipped 800-series Hawkers modified by STC#ST01411SE to reduce maximum permissible altitude to 34,000 feet. “Several instances of aileron/wing oscillations have been reported on the Hawker 800 [series],” the company said. “Aviation Partners and the FAA consider this Service Bulletin to be a safety-related limitation until a design change to preclude the oscillations is developed and FAA approved.”
Aviation Partners COO Hank Thompson said that after meeting with the FAA to discuss these incidents, “We did a great deal of analysis using finite element modeling, refining it and putting different models on the aircraft until we were able to get a model that agreed with what was being reported in flight.” It found that rebalancing the ailerons to a new tolerance forward of the hinge line fixes the problem.
The company tested “every scenario and potential model,” he said, “and every one of them dampened out with our solution.” Aviation Partners will flight-test the solution and then submit documents to the FAA, after which operators will be able to rebalance their ailerons and remove the 34,000-foot restriction. This should be ready next month, Thompson said. The FAA will be issuing an Airworthiness Directive that mirrors the company’s Service Bulletin, he said.
Let's take a wing design that has stood the test of time for fifty years and screw with it.
Designed by the BAe engineers in Britain. You know... the ones that designed the Concorde...
(Okay maybe not the SAME ones but same company.)
With that logic, we should go back to the drag inducing stall fence and ditch the vortilon...
.... or we could hope that mods are well designed and adequately tested.
Have there been other incidents reported?
The original sb did say to slow below m.70 to stop the oscillations. In the 3+ years of our installation there hasn't been any problems in many flight environments.So, if you were to encounter something like this, what would your response be as captain?
I would assume slow airspeed to reduce load and hope for a speed that doesn't induce/maintain the flutter and descend to thicker air... but I'm just guessing.
