Cessna Caravan=172 on steroids..............
And your point is?
Nice write up. At the risk of starting another pointless argument, I'd like to point out a fact I learned in my CFI refresher course this year...there has not been a fuel exhaustion accident in a glass cockpit equipped aircraft. The G1000 fuel range ring is probably one of the largest contributors to this statistic.
That it flies just like a 172 only a little heavier.......... What's your point??
Heck, even the sight gauge and the fuel totalizer in the Dynon d180 in the Remos LSA I teach in makes it shockingly hard to run out of fuel.Nice write up. At the r starting another pointless argument, I'd point out a fact I learned in my CFI refresher course this year...there has not been a fuel exhaustion accident in a glass cockpit equipped aircraft. The G1000 fuel range ring is probably one of the largest contributors to this statistic.
TKS should make it better than anything with boots I imagine.
That's the "fun" part. I had it on the 210s and Barons at Flight Express. LOVED it. On max flow, ice, what ice? Only 75 minutes on that setting though. Tastes good too! Had to divert 3 times due to getting low though. SUPER fun refilling it in Fort Dodge, IA in the middle of a snow storm.Only for about 2 hours.. when Cessna gets it approved (Just to give Pat a hard time). It also has logistical limitations on availability up here, so either pack extra fluid along or don't plan a trip to far away. Also the cost of it just bleeding out into the ether is revenue lost. We have run our 950 Garrett with boots for two winters in the Southeast Alaska ice maker and have only had 1 divert which was due to freezing rain.
Officially, no. Not that I recall off the top of my head at the moment. But if you screwed up and lived, I imagine you'd get tagged with careless and reckless. Us pilots in the Midwest on the longer routes had our "unapproved" way of using it as a de-ice which would give you about 5 hours. On my particular route STP-OMA, I would use it as sparingly as possible to at least Fort Dodge if I could, max flow if things got really out of hand(they never did). Always had at least enough(usually more) to get to my alternate running it on continuous normal flow. What would make me REALLY nervous is the OMA-DEN run(3-3.5 hours each way). Hopefully you did a good pre-flight look at your options! Never had to cover that run in the wintertime thank god.Right after Wings of Alaska birthed out Seaport, they put a down payment a TKS van from Kenmore and tried to run it from PAJN to PAFE, and the math worked out that if you went missed on the way back to PAJN it would be bone dry before the missed approach hold, let alone make the alternate. When Kenmore repo'd it it probably saved someones life. There are enough "fun" aspects in our flying already.. worrying about ice range would be a big issue. Which gives me a question for ppragman or anyone else with a TKS machine. For 135 flight and alternate planning does the TKS endurance become a "controlling" item?
As a customer I'd let you make that mistake about once(diverting because you could no longer fly in ice) before I went shopping. But most routes that anything with TKS flies are very short and that shouldn't be an issue.Officially, no. Not that I recall off the top of my head at the moment. But if you screwed up and lived, I imagine you'd get tagged with careless and reckless. Us pilots in the Midwest on the longer routes had our "unapproved" way of using it as a de-ice which would give you about 5 hours. On my particular route STP-OMA, I would use it as sparingly as possible to at least Fort Dodge if I could, max flow if things got really out of hand(they never did). Always had at least enough(usually more) to get to my alternate running it on continuous normal flow. What would make me REALLY nervous is the OMA-DEN run(3-3.5 hours each way). Hopefully you did a good pre-flight look at your options! Never had to cover that run in the wintertime thank god.
So, crash or cancel is a better alternative? There wouldn't be a single operator in business under that premise.As a customer I'd let you make that mistake about once(diverting because you could no longer fly in ice) before I went shopping. But most routes that anything with TKS flies are very short and that shouldn't be an issue.
Well what I mean is, I'd find someone with an airplane than can handle the route in all weather.So, crash or cancel is a better alternative? There wouldn't be a single operator in business under that premise.
UNpossible. It only takes about 30 minutes to land, fill the tank and get back in the air however if you're Jonny on the spot. I seem to remember being told to stay put in Kearney Nebraska during a blizzard that was still legal to fly. UPS didn't have a fit.Well what I mean is, I'd find someone with an airplane than can handle the route in all weather.
jrh said:Nice write up. At the risk of starting another pointless argument, I'd like to point out a fact I learned in my CFI refresher course this year...there has not been a fuel exhaustion accident in a glass cockpit equipped aircraft. The G1000 fuel range ring is probably one of the largest contributors to this statistic.
I was referring to GA aircraft, which excludes the first two links.
As for the last case....I stand corrected. I did my CFI refresher course online through American Flyers in February, so maybe they hadn't updated their material since the SR20 crashed only a month earlier.
In any case, I think it's fair to say glass cockpits have made a huge improvement in reducing fuel management-related accidents.
