Can't help you out....other than to say, if you absolutely have to be there.....Buy the ticket!!! Buddy passes are just a step above pure evil these days. Regardless of what you decide to do, best of luck!
Yeah, getting on an airplane at an S-4 (Delta friends/family travel) priority is nearly impossible out of LAX most days. My buddy passes don't activate for another few months, otherwise I'd be willing to cut one, but just as has been stated: if you have to be there (as in failing to be there will be a career- or life-modifying event), buy a ticket.Can't help you out....other than to say, if you absolutely have to be there.....Buy the ticket!!! Buddy passes are just a step above pure evil these days. Regardless of what you decide to do, best of luck!
North Bend is regional country. The only way in or out by air, short of bringing your own airplane, is a Brasilia or a Pilatus.+$600??? Have you shopped around for different airports?? That seems awful high this far out.
Eugene isn't far.Let me preface this with: I'm lazy.
Is there a larger airport to fly into and potentially rent a car to drive to North Bend?
You beat me to it. It's only about three hours driving from PDX too, if Google is to be believed, but at that point you're probably better off sucking it up and buying a ticket on UAX.I just searched LAX-EUG using ITA's software. If you go from April 3rd to April 10th (You can vary that to be different) I found air fare for $322 TOTAL on Alaska Air LAX-SEA-EUG, EUG-SEA-LAX.
From EUG rent a car or find a ride down to North Bend. It's only a two hour drive. I bet you can easily get under $600 in travel costs if you do it that way...
Some of it is on a Connection carrier too (which puts Dergh Tylor's passes below my grandma's best friend's boarding priority), and you have to go to SLC first.I'll bet you a dill pickle that a buddy pass through the DL system would be AT LEAST that much.
They used to be great, but they've been a rip for years.
So at that point, is the job worth a $300 risk to be sure you get there.
