Autothrust Blue said:Many 121 transports holler "BANK ANGLE, BANK ANGLE" at 45-50.
"Correcting!"
Or ATC vectored you through.The CFII PTS has steep turns in it. If a course needle is coming in for an inbound hold couse, or an ILS, I would use up to 30 degrees if I had to. It seems better than getting screwed up in an oscillation trying to intercept a course you flew through or the wind pushed you through.
You got vectored into terrain?I have been vectored through a final approach course into terrain. A simple ATC query fixes the problem. No need to make a difficult situation anymore difficult by banking excessively to fix someone else's mistake. Take the 5 minute delay and get a new vector onto the course.
Words about the approach gate, edited.The CFII PTS has steep turns in it. If a course needle is coming in for an inbound hold couse, or an ILS, I would use up to 30 degrees if I had to. It seems better than getting screwed up in an oscillation trying to intercept a course you flew through or the wind pushed you through.
