bc2209
http://www.businessweek.com/videos/2013-01-22/a-giant-floating-airship-could-be-future-of-flight
Looks like something out of star trek
Airships will never be the future of flight. There is a reason so few of them actually exist today. Expensive to operate, they use an extremely expensive and finite lifting gas, they require a crew to launch and recover, and their low speed/maneuverability limits their effectiveness to a few "niche" applications.
Indeed. Unless they plan on filling it with hydrogen or have a helium capture ace up their sleeve (which would be far more valuable than their airship plans...), there's an upper limit on what you can do with LTA even if the launch crew and speed and maneuverability limitations are addressed.
Is there a company using them for certain heavy lift operations now?
Ah, must have been one of those incredibly unrealistic insights into the future of transportation shows on the Discovery channel that I saw that.No. There isn't an airship flying today that has a lift capacity of more than about a ton.
Ah, must have been one of those incredibly unrealistic insights into the future of transportation shows on the Discovery channel that I saw that.![]()
I've always had this idea for moving oil field equipment on the cheap. There aren't a lot of airplanes other than the "big planes" that can carry things like 40' long drilling tools, or move whole rigs - I always thought the airship was well suited for that kind of work.
If you've got billions to develop the airship first, then yes, it might work. The problem is, these companies are trying to develop huge advancements in technology, on a budget to design an LSA, when they need the budget Boeing spent on the 787.
You want something to move that big, get a Mi-26.
I'd straight up go old-school - hydrogen as my lifting gas, etc. Much cheaper...
Other than cost, hydrogen doesn't buy you much, other than a much higher chance of me not flying it. Personally, I don't think manned airships will ever use hydrogen. Unmanned, maybe.
You can't rule out cost, since Helium is so freaking expensive. Zee Germans flew around with Hydrogen for years. If proper safety precautions are taken, it can be made fairly safe. (Positive pressure areas, etc.)
