I wish I was hearing that clearance. Are you 1950?One I got today exactly - N1234, cleared to the Lewiston airport via the Kent Six departure, then as filed. Climb and maintain two thousand, expect FL210 three minutes after departure, Seattle on 119.2, squawk 5142.
I don't fly for AMF anymore.I wish I was hearing that clearance. Are you 1950?
Best thing to remember is the format of CRAFT
Clearance limit (usually the destination airport)
Route
Altitude
Frequency for departure
Transponder code.
Hey all,
I've been doing some searching but didn't find too much info. Does anyone know of a sound file of a compilation of various IFR clearances? I'm trying not to be lazy in creating my own but i know there have to be some out there.
Thanks!!
As other's have mentioned, they all have the exact same format. If it's going to be a long reroute or a convoluted routing the controller will usually tell you, but make sure you're ready to get the clearance and have a pen in hand. Don't be taxiing when you pick up your clearance either - especially single pilot. Do you know how easy it is to slide off an icy runway or smash an airplane up if you're writing down clearances in the airplane while you move about on the surface? When you are taxiing taxi. A lot of freight doggies (myself included until I got a long convoluted reroute) have the bad habit of neglecting to write down the clearance if we have "as filed" because we already know the routing. Grab a piece of paper and write it down, don't "write it into the panel."
I don't think anyone writes out the word craft then a clearance. I would need a steno pad a day if I did that.I tend to write down my clearances in just a line on a piece of paper, writing out "CRAFT" then the routing seems a bit cumbersome for me.
Liveatc.netThe CRAFT is a great method that I do teach my students, but i was hoping to bring in real world transmissions into my discussions. Thanks everyone so far!
The expect is when to expect a clearance to FL210.Daaang 3min? What are ya driving?
What the heck man, did you actually do a charter down here and not tell me?As other's have mentioned, they all have the exact same format. If it's going to be a long reroute or a convoluted routing the controller will usually tell you, but make sure you're ready to get the clearance and have a pen in hand. Don't be taxiing when you pick up your clearance either - especially single pilot. Do you know how easy it is to slide off an icy runway or smash an airplane up if you're writing down clearances in the airplane while you move about on the surface? When you are taxiing taxi. A lot of freight doggies (myself included until I got a long convoluted reroute) have the bad habit of neglecting to write down the clearance if we have "as filed" because we already know the routing. Grab a piece of paper and write it down, don't "write it into the panel." If you're going to get a reroute, have a chart out too, it really helps. Here's an example, you're starting at Merril Field (PAMR):
"Navajo 123AB, unable direct this morning, You're cleared to the Juneau Airport, via radar vectors to Anchorage VOR, then V320 to Johnstone Point VOR, V319 to Yakutat, after Yakutat, V440 to HAPIT, then V317 to Sisters Island VOR. Climb and Maintain One-Zero Thousand, expect One-Two Thousand Ten Minutes after departure. Departure Frequency is 126.4, Squawk 4523."
If I were to write this clearance down, it'd look something like this:
JNU RV TED V320 JOH V319 YAK V440 HAPIT V317 SSR M100x120-10 126.4 4523
rframe said:Here's what you want to hear.
N55443 below radar coverage, traffic advisories not available, squawk 1200, goo'day.
You do know that radar coverage is not a prerequisite for IFR flight, right?
