spoolinup22
Post it notes seem to be a bit more challenging and it's not recommended to pull the breakers so what's everyone's method of ruining their students day?
Simulated failures don't work unless you pull breakers in the actual plane. As you said that is not recommended. A simulator is the only way to properly train someone for failures within the G1000 system and likely other glass cockpit options.
Yes, but it's more intense and real in the airplane when you're flying a Cessna 172 and your scan is awful twisting your head all over the place to see your standbys (below the G1000), the MFD, and looking up at the compass for magnetic heading... I'll have to send you a photo of what I use to cover parts of the screen that simulate failures. I just realized you asked in general... I was assuming Instrument training.
As a private pilot the biggest thing you can do is just cover the screen completely. We have velcro above each screen, and a black piece of clothe that we stick over a screen to simulate a PFD or MFD failure for our Private students.
What failures did you have in mind specifically?
I'm thinking instrument here as well. All a private pilot should have to worry about is the screen going black. Partial failures aren't as bad.
During instrument it still isn't realistic for failures to just cover stuff up. An ACARS failure will cause the HSI to turn into a classic Nav. You will lose a set of Coms as well I believe. You can't appropriately do instrument approaches in the aircraft during training while simulating an ACARS failure without pulling a breaker.
Yes heading and such can be done but you can't do a VOR approach partial panel.
Not to mention the needle moving around on the HSI gives the student a good visual reference for heading.
No idea why I was saying ACARS.
AHRS failures can not be be fully done in the aircraft. Yes heading and such can be done but you can't do a VOR approach partial panel. Not to mention the needle moving around on the HSI gives the student a good visual reference for heading.
In the G1000, a loss of AHRS doesn't normally affect the navigation equipment (GIAs), so you should still have VLOCs and GPSs. You can even do ILS and LPV approaches with the AHRS inop.
Sent from my iPad using Tapatalk HD
I agree with you on that one.Talking about training for the failure. Since pulling the breaker is frowned upon there really is no good way to properly simulate the failure.
What are the odds that Joe Blow has been trained to do that without primary attitude-heading information on a G1000 airplane? Not trying to belabor the point here, but...In the G1000, a loss of AHRS doesn't normally affect the navigation equipment (GIAs), so you should still have VLOCs and GPSs. You can even do ILS and LPV approaches with the AHRS inop.
Great points taken. I guess I should really revise the thread to ask what kind of emergencies you give your private and IFR students.
So far it sounds like private is best to cover the entire screen and or dim the lights.
IFR- reversionary mode, best in simulator
While that is true, the wiring especially as the aircraft age and get modified is going to be the weak point. While I have never seen an AHRS physically fail, I've seen lots of EFIS components go offline or become intermittent due to damaged wiring. Granted, Cessna probably did a lot better job routing and protecting wiring in their new aircraft than most folks do in a retrofit install, but the possibility remains.The mask isn't a perfect way to simulate a failure, but it's pretty good for meeting the FAA PTS. Simulators are the best to train for G1000 failures, but really when it comes to AHRS/ADC dual failures I think the PTS needs to be revised to reflect the miniscule odds of that failure scenario. I've written up quite a few vacuum powered standby attitude indicators, but never once had an AHRS/ADC dual failure. If I recall, the mean time between failures for the GDC/GRS is on the order of 10,000+ hours.
