 FLXs big thing in training is weather, weather theory, and how to use ALL the products. Not just the aviation ones either. Everyone seems to struggle with this. Not just the airline guys.  Reason being is that you're by yourself, the dispatchers don't make any calls, and there's absolutely no cancelling.  Only "when can you go".  You have to be able to accurately make that call.  Temp/dew point spread for when fog is going to start/lift for example.
Yes, and yes. I'm not sure, but the implication of the above seems to be that FLX training is "a cluster", which is not the case. Austin is an absolute font of knowledge about 135 and flying in general, and the training is extremely "structured". It's just also kind of difficult. *shrug*. It's nothing that Joe Pilot shouldn't be able to handle, but it does pretty much require that you show up already knowing how to fly IFR to minimums in a /U piston single and that you show up, pay attention, and stay awake in class and spend significant amounts of your down time actually studying. Some people seem to have difficulty with one or the other of these things. When I was there the washout rate hovered around 50% generally.
AFAIK, UAL is the only guy here who has been through both FLX and AMF training...perhaps he could explain the differences for those who are...guessing?
BTW, here's another pepsi challenge. Having flown a fairly significant amount of single pilot freight and having spent a fairly significant amount of time blasting around in a jet, flying freight is A) More demanding and B) More fun. That's not a guess.
Unimpressed because they go around the storm rather than through it?This is seriously not a troll post, even though I'm sure it will come off as one. However, from the Alaska guys I've seen try to hash it out in freight, they've been pretty tame with weather flying compared to the rest of us. I'm sure you guys can scud run with the best of them, but when it comes to weather flying, I'm not all that impressed.
I'm not sure why we do this in this industry, but "a complete cluster" is translated as "demanding" and "challenging," and "structured" is "too easy" to some folks. Me? I'm not very smart, and I like being told what I'm going to be checked on, but it's possible I'm just a horrible pilot.
Okay, the letter from the chief counsels office regarding the word "assignment" in 135.267 was something the 121 guys couldn't grasp. 121, you'd never go WAY over duty, but under 135.267 and that word "assignment", technically you can. It's a slippery slope however. We've hashed this out before in another thread with no real result. The letter FLX presented to us is not online. Hmm....
Sec. 135.267 — Flight time limitations and rest requirements: Unscheduled one- and two-pilot crews.
(a) No certificate holder may assign any flight crewmember, and no flight crewmember may accept an assignment, for flight time as a member of a one- or two-pilot crew if that crewmember's total flight time in all commercial flying will exceed—
(1) 500 hours in any calendar quarter.
(2) 800 hours in any two consecutive calendar quarters.
(3) 1,400 hours in any calendar year.
This is all pretty straight forward, nothing of merit to see here other than that 1400hrs per year is a crap-load of flying and no one should be voluntarily subjected to the schedule it requires, but it is perfectly legal.
(b) Except as provided in paragraph (c) of this section, during any 24 consecutive hours the total flight time of the assigned flight when added to any other commercial flying by that flight crewmember may not exceed—
(So remember, we've got to go to paragraph (c) for the exception, and how it applies but the rest of the time, this stuff below is the critical stuff)
(1) 8 hours for a flight crew consisting of one pilot; or
(2) 10 hours for a flight crew consisting of two pilots qualified under this part for the operation being conducted.
(Pretty obvious, don't exceed 8 in 24 for single pilot, don't exceed 10 in 24 for 2 pilot crews - the FAA has a chief consul article out about what to do if you are both two pilot and single pilot - it's easy enough and follows those rules to the strictest interpretation.
(c) A flight crewmember's flight time may exceed the flight time limits of paragraph (b) of this section if the assigned flight time occurs during a regularly assigned duty period of no more than 14 hours and— (Alright, so if you have a regularly assigned duty period - which means that it starts and ends at the same time every day then you can intentionally go over your flight time limitations, but you'd better have a policy in place if you read through the interpretations, "regularly assigned duty periods" must start and end at the same time every day and be followed by 10 consecutive hours of rest - note that this is the only time in the regs where it talks about duty period - generally the FAA doesn't give a damn about duty period, they want to know about your rest periods.)
(1) If this duty period is immediately preceded by and followed by a required rest period of at least 10 consecutive hours of rest;
(2) If flight time is assigned during this period, that total flight time when added to any other commercial flying by the flight crewmember may not exceed—
(i) 8 hours for a flight crew consisting of one pilot; or
(ii) 10 hours for a flight crew consisting of two pilots; and
(3) If the combined duty and rest periods equal 24 hours. (So, no going over the duty time limitations in here it must be equal or under 14hrs)
(All this really means is that if you're a scheduled operator in Alaska using 135.267 rules, or you're an unscheduled operator that does a lot of trips during specific times of day, you don't have to worry about busting your 8-in-24 limitation under the previous paragraph. It means that if you have one day where all of your flights are in the evening and you fly 5 hrs, and the next morning all of your flights are in the morning and you fly 5 hrs, even though your rolling clock has ticked over 8-in-24hrs, you're still legal).
(d) Each assignment under paragraph (b) of this section must provide for at least 10 consecutive hours of rest during the 24-hour period that precedes the planned completion time of the assignment.
(This is where the idea that you have a "14hr duty day" comes from, normally, you must be given 10hrs of rest prior to a duty assignment, so operators say, "Well, that means I can use my pilots for up to 14hrs! That means there's a 14hr duty day! - no...it doesn't, it means you need 10hrs of rest prior to a duty assignment.)
So, if you "report for duty" at 10:00AM, that means that you had better have gotten off and "dutied off" before midnight the previous night. If work for 4hrs and during that you fly a 1hr out and back trip, and duty off at 2:00PM, that means the earliest you can duty on again is midnight that night. Clear as mud?
(e) When a flight crewmember has exceeded the daily flight time limitations in this section, because of circumstances beyond the control of the certificate holder or flight crewmember (such as adverse weather conditions), that flight crewmember must have a rest period before being assigned or accepting an assignment for flight time of at least—
(1) 11 consecutive hours of rest if the flight time limitation is exceeded by not more than 30 minutes;
(2) 12 consecutive hours of rest if the flight time limitation is exceeded by more than 30 minutes, but not more than 60 minutes; and
(3) 16 consecutive hours of rest if the flight time limitation is exceeded by more than 60 minutes.
(If something abnormal happens, you can go over, but you have to be given more rest - in the industry this is often referred to as "Compensatory Rest" - why? Hell if I know, the company is compensating me for anything, I worked extra and it's required, but whatever.)
(f) The certificate holder must provide each flight crewmember at least 13 rest periods of at least 24 consecutive hours each in each calendar quarter.
(13 rest periods of at least 24hrs are required per quarter - pretty straight forward)
[Doc. No. 23634, 50 FR 29320, July 18, 1985, as amended by Amdt. 135–33, 54 FR 39294, Sept. 25, 1989; Amdt. 135–60, 61 FR 2616, Jan. 26, 1996]
An additional caution is that it is a violation of FAR 91.13 for a certificate holder or a flight crewmember to operate an aircraft in a careless or reckless manner so as to endanger the life or property of another. Lack of rest of the pilot is certainly a circumstance which could endanger others, and it is not necessary that the situation devolve into actual endangerment for there to be a violation of FAR 91.13. A certificate holder who uses a crewmember with knowledge of his or her lack of rest may be equally culpable along with the flight crewmember.
Rest period means the period free of all responsibility for work or duty should the occasion arise.
I never said it wasn't structured. It is not as structured as some places I've been but there is a semblance of structure. I'm just saying it's not the fire hose, pull your hair out, 20 hour day studying training some make it out to be. They cover the topics you need to know in a fairly orderly fashion and you leave. Cooperate and graduate. I think some 121 guys might fall victim to the "I'm only flying a Navajo, wake me up when it's the checkride" and for that they are stupid.Amflight's training, at least when I was there, is what you would call "structured" and "well thought out." Say what you want about the pay or how they treat you (and there's a lot to be said), I found Amflight's training and operational philosophy to mirror the part 121 carrier I'm at.
A cabin class piston twin is probably one of the harder airplanes to fly OEI. Give me turbines any day, way easier.I never said it wasn't structured. It is not as structured as some places I've been but there is a semblance of structure. I'm just saying it's not the fire hose, pull your hair out, 20 hour day studying training some make it out to be. They cover the topics you need to know in a fairly orderly fashion and you leave. Cooperate and graduate. I think some 121 guys might fall victim to the "I'm only flying a Navajo, wake me up when it's the checkride" and for that they are stupid.
Heh...well, not really.
ppragman's post.
Yes, I'm aware of all the 91 home shenanigans and how 24 hours on call is still duty. What I'm on, and what Flight Express focuses on, is the word assignment and what FLX considers an assignment as spelled out in the letter from the chief counsel interpreting that word. I'll find the thread where we hashed this out. Dugie8 and I dug through this until we were blue in the face. Going by that thread, it contradicts what FLX considers and assignment and "circumstances beyond the operators control" concerning that assignment. BUT, Austin has a letter from the chief counsel interpreting "assignment" the way FLX does. I haven't found it online anywhere however. Hence the "Hmmm...."
That being said, we never messed around with .267 as it would royally screw up the entire week.
Don't take what I said in thy thread as nothing but rambling bi wasn't thinking in terms of assignment bi fly air ambo, thus on demand.Yes, I'm aware of all the 91 home shenanigans and how 24 hours on call is still duty. What I'm on, and what Flight Express focuses on, is the word assignment and what FLX considers an assignment as spelled out in the letter from the chief counsel interpreting that word. I'll find the thread where we hashed this out. Dugie8 and I dug through this until we were blue in the face. Going by that thread, it contradicts what FLX considers and assignment and "circumstances beyond the operators control" concerning that assignment. I'm also in agreement with what Dugie8 found, BUT, Austin has a letter from the chief counsel interpreting "assignment" the way FLX does. I haven't found it online anywhere however. Hence the "Hmmm...."
