inigo88
Composite-lover
Yes. As do new build cessnas.
What do you think the problem is then? I know aluminum has some "give" to it (eg large plastic deformation curve) and will bend to some extent to absorb an impact. Carbon composite and fiberglass on the other hand has a very short elastic & plastic deformation curve. In other words they will take a lot of stress without bending, and then instead of bending and absorbing the force they just shatter spectacularly into little splinters of glass/carbon/resin.
Is that a fair assessment, and if so, do you think an AD as simple as a conventional fuel bladder in the wing that would be a more flexible barrier in case the composite ruptured?
I suspect the lesson here may be to not make wet wings out or brittle material. But I have no data to back that up. (Disclaimer: Not saying composite = dangerous. But it definitely raises new engineering problems and can't be treated conventionally.)
