Blip16
How would i even know?Ok what if your taxing out and number 3 in line with 10 behind you waiting for take off and it burns out. WYD?
Sent from my SPH-D710 using Tapatalk 2
Tower keys up and says "Air Carrier thirty three eighty nine..."How would i even know?
Yes actually.have you ever heard a tower do that?
i guess i have too just once though, and my lights were on because I could see them reflecting off the ground (for real, not covering it up).Yes actually.
Yeah. It doesn't happen frequently (they are experts at minding their own business) but I've heard it. And seen someone do a return because of it.i guess i have too just once though, and my lights were on because I could see them reflecting off the ground (for real, not covering it up).
That amazes me... Most of the time its like you said, minding there own business, and you can't believe they just let an aircraft do something.Yeah. It doesn't happen frequently (they are experts at minding their own business) but I've heard it. And seen someone do a return because of it.
We've had three pilots at FLX get busted for doing this. It's as simple as an FAA guy sitting in the parking lot watching you. In both cases, the pilots in questions saw it on pre-flight, or should have.It burned out after takeoff right?
Thats why i go to XFL! Cause FLX blows.... :Sarcasm:We've had three pilots at FLX get busted for doing this. It's as simple as an FAA guy sitting in the parking lot watching you. In both cases, the pilots in questions saw it on pre-flight, or should have.
No certificate action, just a stern talking to.
Just sayin, this excuse will never fly if the FAA brings a case against you about it. Not likely they would I'm guessing.
I'm no expert but I think it's a light that navsNav light??? What's that for???
This is why my airplane carries two sets. An (M) procedure exists for a mechanic to come out and activate the other set.This just happened to me last week. Got the paperwork, FO finished up the weight and balance, and one of the ramp guys says, "Hey... ya'll have a nav light burned out."
I called MX and deferred it per the MEL. We were late, but we were legal.
What do you fly? The second light comes on automatically when the first on burns out on the dash, I assumed all aircraft with 2 lights did this.This is why my airplane carries two sets. An (M) procedure exists for a mechanic to come out and activate the other set.
Redundancy is good.
Embraer Jungle Jet/BrasiliaJet/Reset JetWhat do you fly? The second light comes on automatically when the first on burns out on the dash, I assumed all aircraft with 2 lights did this.
Well that should go with out being said, but I had no idea that you had to throw a switch to turn on the back ups. As I said, in the dash there are two lights in each wing. A fore and aft, when the fore goes out the aft automatically comes on, then you write the forward (primary) light up. I would like to hear how other aircraft like Boeing and Airbus products operate, whether it is automatic or manual.Indeed, there's a switch to go from primary to the backup lights in the breaker panel behind the captain's seat.
That being said, it shouldn't be thrown without MX doing it, and/or MX supervision, and/or making sure it's in the book and MEL'd properly or a crew down the road could be hosed when the backup burns out and nobody knows that somebody flipped the switch.
Or said another way, follow your company guidance on the issue and don't just start mashing buttons and flipping switches on your own.
