Autothrust Blue
“If you jump on my shift, that’s just rude, man.”
Mine either. Even then we have a redundant set.My nav lights don't burn out. Mystery of the universe.
In an interview, they aren't looking for someone to say the they'll be a "team player" and look the other way. They want to know that you're a guy who follows the rules.
What to do, what to do... I just got a job flying jumpers and have noticed that they prefer me to not notice mechanical problems. I try to find the balance between safety and efficiency... I guess that would be my answer.
I don't know about that one, I think it really depends on the company there. It sure seems like a delicate dance for the interviewee... not wanting to seem like an FAA boy scout while at the same time not wanting to look like a total John Wayne (cowboy).
Tell Delta that you "try to find the balance between safety and efficiency" and the interview will be over.
Come to think of it, I think the Soviets actually had less flare than Delta.![]()
You guess right, but honestly I haven't had an FO approach me about a burned out light in years. I have FA's tell me we have burned out emergency lights more often than burned out nav lights. Mx does a pretty good job here.
Yep... Their rule is 1 pin... 1 pin only.
That's what I ask through 10,000ft. If its smooth "one ping only?" If not "two pings"
Are there any limitations on your airframe with a nav light MEL'd?On a serious note, and slightly on a tangent in RW this drives me up the wall! For our operation with the RJ, it is a simple write up with a simple response and one placard. I swear, 9/10 times when I tell the CA, hey we have a nav light out...they just stare at me and go back to what they were doing. What is so hard about writing that up. Now before we go any further, I realize I have the ability to write it up but it always has been a CA thing to write planes up and you are known as "one of those FOs" if you go writing stuff up. But really? Is it that hard. We aren't talking about something that will jack up a commute but a dumb bulb. I just hate the attitude of "someone else will write it up" or "they will figure it out on the ISC". Laziness!
No. We have two per wing and two on the tail. As long as both aren't out, it is a simple placard with no limitation. I realize the insignificance of it but it is just laziness and puts the FOs in a bad spot.
Don't you mean the other way around? It always seemed that these burned out in the hub (where the maintenance just happened to be located).Which is, of course, the same answer. Nobody has ever, nor would they ever find it in the hub.
"Call maintenance" is not a bad answer, but the part about being able to MEL it if they say you can is not the right answer. I've seen maintenance (and dispatch), try to convince captains that things were "A-OK" when they were not. There is a story about a CRJ with a sawed off Pitot tube (I think Bombardier was shocked the pilots did not crash it). Heck, every airline pilot probably has a story. If it is not on the MEL that you can read... it isn't.In an interview, answer is simple: call maintenance. If they say that it can be MEL'd, then MEL it. If it's a no-go item, then you don't go. In an interview, they aren't looking for someone to say the they'll be a "team player" and look the other way. They want to know that you're a guy who follows the rules.
Sorry. What was I thinking. I mean of COURSE ATC will give you direct to KATL as dispatch flight planned it so you would not exceed your duty day.What are you talking about? Maintenance and dispatch would never lie to you. Ever.
