Welcome...Good Luck...Do you have your FE written done...
not if you want to be a Flight Engineer...does that help?No. I have an ATP though. Does that help?
smartass comment
MINIMUM QUALIFICATIONS: FAA Flight Engineer, a second-class FAA medical certificate. Experience in the B-727 preferred. May consider candidates with the FE written exam. Candidates with an Airframe or Powerplant license will be given additional consideration not if you want to be a Flight Engineer...does that help?
So get the King School FE exam prep and take the dang test.
I thought that having an ATP would trump the FE written since it's the highest grade certificate you can get..
Sorry, it appeared that you applied knowing that you weren't qualified...
And what good does more bickering & attacking do?
Movin' on...
Movin' on...
Regardless, he's a moderator, he should be setting the example.
What do you intend on accomplishing? As far as I know, there's every Tom, Dick and Harry that Googled "Kalitta 727 Jobs" that are watching this thread turn into a slow motion train wreck. You two are having a personality conflict and I don't think the website, at large, gives a poop so handle it like a man.
I can assure you that there are more eyeballs watching the forum than is readily apparent.
