Taxi question
Legally or is it possible? It is definitely possible to not only taxi but also fly one single pilot. In fact, part of check airman training is doing just that.
When I was a ramp-rat at UPS, MX taxied to the runup area all the time, and in-house "taxi-authorization training" was the only authorization they had to do so I believe, other than getting a taxi clearance in/out of the movement area each time from grd control.
I was referring to whether it was legal.
I cant imagine that its ok for someone who is not an A&P or a licensed pilot to simply get into an airplane and taxi around the airport. Example; re-positioning an aircraft from one FBO to another one across the field, entering the movement area, recieving taxi instructions, crossing runways, etc.
As for A&P's, I think part of the General mechanic training, you are required to be trained how to taxi an airplane. thus the certificate gives you the privilege.
Maybe I am missing something...? But to me, it sounds like you must be a licensed pilot or mechanic to taxi an aircraft, thus if it is a two crew aircraft, the FO must be on board. Does UPS allow thier mechanics to taxi 747's and DC-10's around solo? If nothing more, its nice to have a second set of eyes to clear the right side.
It's legal. May or may not be safe, depending on the environment and the driver's experience. Some airports might impose their own training requirements?
This is what I was taught.
Yes it is legal.
The reason it can be done is that the purpose of the aircraft movement is for something other than departing on a flight.
The flipside of that is, even if you did have your license and medical on you, you could not log that time for the same reason.
When I was taking ME training, had one flight that we taxied out to the runup area, had an engine that wouldnt cooperate, taxied back, aircraft down, flight lesson got cancelled, yet I was still able to log that time because the purpose was for an actual flight.
Now I could be wrong but it at least sound good and logical.
Well since you don't even need a pilot certificate to taxi an aircraft...
This sums it up right here. Joe the hobo could jump into a 747 and taxi around the airport to his heart's content. The FAA won't care. TSA probably will as the hobo most likely jumped a fence.
Imagine it. You can taxi a 747 all over the airport anytime you want provided you get a clearance for ATC if applicable.
I never got that training in A&P school.
You are confusing FAA requirements with insurance requirements and company SOP.
If I paid 50 million dollars for an airplane (or insured it) then no way am I going to let anybody off the street drive it around the airport. However the FAA doesn't care if you run a shiny new 747 into a drainage ditch.
what if you get a runway incursion? whos responsible then? they dont have a certificate to pull (which is about all the FAA can do to punish someone)
what if you get a runway incursion? Who's responsible then? they don't have a certificate to pull (which is about all the FAA can do to punish someone)
One of the great things about the FAA (yes I meant to say that) is if we do a good job of policing ourselves (requiring extensive training before being allowed to taxi a jet around an airport) then they don't see any need to make any formal rules.
A "run/taxi liscense" that a mechanic gets from their employer is not issued by the FAA, but the FSDO knows that the airline has a training program before Joe mechanic taxis around the airport.
The same thing applies to skydivers. The FAA does not regulate training or liscencing of skydivers, the USPA has done such a good job of regulating themselves that there is no need.
Runway Incursion, Schmunway Incursion. Only thing a 707 can't do is read
Here where I work, we actually TOW aircraft across active runways at ATL international during the day AND at night, using FMC "Expeditier" tugs, using one person. I don't neccesarily agree with this, but been doing it for over 5 years now.. We do require 2 qualified technicians in the cockpit during taxi operations, however...I physically could taxi by myself, but not legal per company regulations....We, as techs here, AVERAGE about 300 moves per year here at Hartsfield....BY OURSELVES...
Yes it is legal.
The Part 1 definition of flight time includes the requirement for the aircraft to come to a stop after landing, in addition to the moving under own power and intent requirements. Thus you cannot legally log flight time when you get a bad mag and return to the ramp.
Can they if you don't have a pilot certificate? I've always heard that if you don't have a pilot cert, and go get into a heap of trouble the faa can't do much.
That sounds like one of those myths like not handing your pilot cert to an FAA inspector when they want to look at it. If the EPA and TSA can fine you, I'd imagine the FAA can do the same whether you hold an airman certificate or not.
