gliderboy
Might be a blessing in disguise. One of lead's functions in gasoline is to inhibit detonation. However, ethanol (like that found in mogas) also inhibits detonation.
Lead is also said to protect exhaust valve seats. However, as someone who restores and rides old motorcycles from the sixties, I can well remember the howls of protest which arose when lead was first removed from mogas. "Our engines are all going to blow up. We'll need replace all our valve seats with harder seats." Etc. Guess what happened. Nothing. The old bikes run fine on lead-free. (Even my high-compression 750 Triumph hot-rod runs fine on it.) Still, upgrading the engines with harder valve seats, if needed, is not a big deal
Which leaves us with the water absorbing qualities of ethanol. Cars deal with it, no reason airplane engines can't be made to do so. New fuel pumps, new rubber compounds, etc.
And unlike gasoline, which cannot absorb water, ethanol can hold water in suspension, allowing the engine to burn it.
Rather than complaining, why not make the planes run on mogas and cut our fuel bills by 25%?
In other words, if engines and their supporting systems are modified to run on mogas the price of 'avgas' will drop by 25%! Might be a good idea.
Most typical GA engines are a product of 50's and 60's era technology. Magnetos with fixed and very primitive ignition curves, carburetors instead of injection. It's time to bring GA engines into the present. The Rotax engines used in todays' light sport planes are loaded with the modern technologies which could be easily applied to larger GA engines. The Rotax is designed to run on mogas and pumps out way more horsepower per cubic inch of displacement than the old clunkers in most of our planes.
Mogas — change you can believe in.
