staglia
Right seat
Took the multi-engine add on checkride today (passed) but the DPE gave me a hard time about doing power-on stalls with the gear up. When we landed, he showed me that the PTS says:
C. TASK: POWER-ON STALLS (AMEL and AMES)
REFERENCES: FAA-H-8083-3, AC 61-67; POH/AFM.
NOTE: In some high performance airplanes, the power setting may have to be reduced below the practical test standards guideline power setting to prevent excessively high pitch attitudes (greater than 30° nose up).
Objective. To determine that the applicant:
1. Exhibits knowledge of the elements related to power-on stalls.
2. Selects an entry altitude that allows the task to be completed no
lower than 3,000 feet (920 meters) AGL.
3. Establishes the takeoff or departure configuration. Sets power to no less than 65 percent available power.
4. Transitions smoothly from the takeoff or departure attitude to a pitch attitude that will induce a stall.
5. Maintains a specified heading ±5°, in straight flight; maintains a specified angle of bank, not to exceed a 20°, ±10° in turning flight, while inducing the stall.
6. Recognizes and recovers promptly as the stall occurs by
simultaneously reducing the angle of attack, increasing power to maximum allowable, and leveling the wings to return to a straight- and-level flight attitude, with a minimum loss of altitude appropriate for the airplane.
7. Retracts flaps to the recommended setting, retracts the landing gear if retractable, after a positive rate of climb is established.
8. Accelerates to VX or VY speed before the final flap retraction; returns to the altitude, heading, and airspeed...
Thoughts??
Thoughts??
