jrh
Here's a question for the instrument gurus here...
Suppose you have a non-precision IAP that does *not* use DME distance or a crossing radial to define the MAP. The only method published for defining the MAP is time. For example, an approach like this:
http://204.108.4.16/d-tpp/1104/05540VA.PDF
May a pilot use an IFR certified GPS to determine the MAP, rather than time?
Or must time be the determining factor, even if the GPS indicates otherwise?
Now, here's the challenge...whatever you say, back it up with solid, written references. "My instructor," "My examiner," "My local FSDO inspector," etc. don't count.
