If you are that concerned about it then get guidance from your local FSDO not what everyone else on this forum says.
First, as I've said, I'm not concerned with the answer. Second, If I really was concerned, why would I get guidance from the single worst place - the local FSDO where the answer could depend on who is on duty that day? (Ever been with two inspectors who disagreed with each other about whether certain conduct violated a rule?)
As far as I can tell, this has been primarily an academic discussion, with most people saying in effect, "Of course I'd use the most reliable source to tell me where the MAP was. I'm just wondering whether there is a rule on it." If you don't want to join in the spirit of that kind of discussion, you're welcome not to.
If it does not say it in the reg's it's fair game as far as FAA goes.
As a general rule, not really. There are hundreds of FAA Chief Counsel interpretations, some of which either permit or don't permit something based on interpretation and even expansion of the strict wording of the FAR.
The reg says,
Instrument approaches to civil airports. Unless otherwise authorized by the FAA, when it is necessary to use an instrument approach to a civil airport, each person operating an aircraft must use a standard instrument approach procedure prescribed in part 97 of this chapter for that airport. This paragraph does not apply to United States military aircraft.
So, when the timing box is on the plate and there is no DME fix, GPS waypoint, or intersection that identified the MAP, is the timing box part of the "standard instrument approach procedure prescribed in part 97 of this chapter for that airport" that must be followed by the pilot? Don't think it can be expanded that way? This is the same rule that led the Chief Counsel's office (and the AIM, although one is "non-regulatory") to say that a depicted PT mist be followed regardless of whether the pilot thinks it's necessary to reverse course.
