One person mentioned decending only 20' below class "B" another mentioned he was only 200' below class "B" and apparently the controller providing advisories didn't see a need to issue any type of advisory concerning the proximity to class "B". In this case maybe it wasn't an issue, however for you rated controllers to come on here and advise pilots seeking professional advise that they have no worries flying right up against a class B floor are providing dangerous advise. All of you should be familiar with proximity operations since It was mentioned in one of my first post and is in the .65
You have radar contact and radio communication with the a/c and slide the VFR just below class B for ifr traffic and then have him fall out of the sky for failure to provide some type of separation and you will be in a world of hurt. Simple solution is to provide the advisory and have the vfr maintain visual separation. It takes you less then 5 seconds to spit it out and you've covered your rear, plus it keeps the pilots informed as to what going on around them and prevents any oh sh__ moments.
The bottom line is this a/c was told by atc to descend leaving class B, so until the aircraft is safely out of the proximity of the class B floor, atc is responsible for separation. After all controllers must exercise their best judgment based on the facts and circumstances known to them. That action which is most critical from a safety standpoint is performed first.
