All performance data is supposed to be calculated without credit for thrust reversers, right?
That's a good point. Perhaps braking action was reported better than it was. Just looking at the numbers, if braking action was calculated as good when it was actually medium or worse, the aircraft could easily find itself out of runway without reverse.
dont know much about jet airplanes since I fly piper cadets "haha" but I have read about the air/ground logic system, could it have been related to that?
My "memory" is that for auto-ground spoilers (lever in the armed detent) you need: (1) hyd pressure to both MLG tilt actuators, (2) both trucks detect no-tilt, and (3) both throttles are at idle.
But even if the lever is not in the armed position and those three conditions are present, the spoilers will automatically extend if either reverse lever is raised to its stop.
Wheel spinup required?
Biggest thing I hate: I land, can barely control the airplane for all the ice with the airplane trying to weathervane into the wind, any application of brake immediately locks a tire up, and I report "breaking action nil," then to keep the airport open, tower immediately sends out the truck with studded snow tires to cautiously slide down the runway, to report 5 minutes later that "braking action is poor." Its not really a factor with big runways and little airplanes, but I reported that not because I really cared, but because the 737 that's going to land there in 30 minutes might care. But whatever.
Braking action was good for the first 2/3rds of the runway and poor the last 1/3rd. I reported it as good braking action but I was in a 1900, and never used the last 1/3rd of the runway. I don't recall what the Saab friction tester (Mu Readings) reported Im sure I wrote it down somewhere. Pilot reported a mx problem and so far the mechanics have confirmed it. Well see what the NTSB says.
Minuteman is dead on. No spinup required. It's just based on truck tilt.
I can't remember anymore... what sort of indications are there of an air/ground sensor fault?
If it weren't for the reverser eventually deploying in that video, I would guess that the L HYD SYS lost all its fluid. That would take out the tilt actuators, inhibit the spoiler logic, and prevent the left reverser from doing anything.
Do the 757's have any engines that activate the TRs via Bleed Air?
Who knows what caused this. It's one of those things that happen for one reason or another.
Those of us that it didn't happen to should remind ourselves that we fly machines, and anything can happen at any time. They have no discretion or care when a minor or major malfunction occurs.
Be safe out there.
