jynxyjoe
Queso King
If you are going oversquare, you might as well be putting gun powder in your fuel tank.
That's recommended procedure isn't it?
I am an engineer... We don't write rules like that, we test and make tables & charts. We only put rules like that in the book when the lawyers tell us to.
I'm glad you can speak for all engineers, everywhere.
The "over square" rule of thumb (and that's all it is -- a ROT, which means it doesn't technically apply to all engines under all circumstances) comes from a time when big pistons ruled. With big pistons swinging big props, the inertia of the prop was as important a factor in the health/life of the engine as the inertia of all the pistons moving inside the engine.
Read up on "reciprocating loads" from Randy Sohn to get some background understanding of what drove the MP = RPM rule of thumb.
http://www.douglasdc3.com/sohn/3.htm
The argument can be made that these same forces are at work inside smaller pistons swinging smaller props, but as has been stated, manufacturer's operating specifications always trump ROTs.
Right but in your example, what happens if you leave the throttle wide open, and run the RPM's back to 2000?
Pretty good explanation as to why there are limits of flying oversquare.
BMEP = Brake Mean Effective Pressure
Definition: BMEP is the theoretically determined constant pressure that could be exerted in the combustion chamber during each power stroke to produce the actual Brake Horse Power. (definition from the book quoted above)
Douglas recommended this book to me and I also highly recommend the book for CFIs or anyone else that wants to learn more about piston engines. You don't even need to be flying high performance aircraft for the book to be a great tool.
True! "Flying High Performance Singles and Twins" is a great book. I'm glad you read it.
The book isn't cheap, it isn't a page turner, but it will simply take the reader to the next level of piston/aircraft knowledge.
The first chapter is titled "The Air"
I had been teaching flying for two years and cockily started reading "The Air" but it knocked me on my butt in 10 pages.
Somebody likely taught this as a rule of thumb in another time, and it stuck around for who knows why.
Read the POH. Fly that. Can't go wrong doing what the engineers told you to do.
Actually, you can. Engineers only flight test the aircraft to certain, fairly arbitrary limits. The power plant, while being thoroughly tested may not have been tested in the type of operation that you use. Best bet is to find an operator who's been doing it for years and ask them. Consider this for example, I was doing a takeoff and a landing in the 206 and PA32 on average every 26 minutes if my log book is to be believed. I doubt Continental and Lycoming predicted that style of use in a cool, damp, salt rich environment.
Don't ask the engineer who tested the thing in california for 9 months. Ask the operator who did the operation in your region for 20 years. That guy is bound to know a bit about what makes the things last to TBO.
Unfortunately, however, operators will often mistake a cause and effect and perpetuate myths that have no factual basis and make non sequitur assumptions/arguments. As an example I have sometimes heard a pilot state that leaning the mixture during taxi will burn a valve and they will site some person who leaned their mixture during taxi and a valve got toasted at some point. They mistakingly tie the leaning during taxi with the burned valve- the two are not related.
This is not incorrect. Take all hangar talk with a boulder of salt. That said, when a company notices that they are burning through valves left and right, then changes a procedure, and suddenly the problem goes away, it might be an accurate diagnosis of a condition, or at least the technically incorrect logic behind whatever change they made had decent results.
Take for example dreaded "shock cooling," I know of at least a half dozen operators off hand that stage cool their airplanes to prevent excessive reductions in CHT. The Continental and Lycoming manuals list a maximum change in CHT over a given period of time that is acceptable. The operators are in this case simply narrowing the allowable margin. Coupled with good preventative maintenance these techniques can depending on the implementation, be more conducive to engine longevity than the tolerances defined in the engine's operating manual. That doesn't mean that you shouldn't run "ovEr squreD" (OH TEH NOES!!!), and as always, you must consider the source. But operators are highly concerned with their bottom line, and given time may develop highly accurate ways of increasing engine life.
I lean aggressively during taxi. I didn't say that leaning aggressively during taxi caused burnt valves. What I said was that when a company changes something and has a problem go away, they tend to stick with it and its probably a good thing. Reading comprehension here man. I do know 207 operators that have said, "don't lean other than taxi," or "don't touch the mixture and stay below 1000'." Then they have the mixture adjusted to give about 18GPH at the cruise power setting. Nothing wrong with that if the company finds that its jug cracking / valve burning problem goes away in that particular kind of operation. An operation that has terrain to clear, and will have to frequently go above 1000' might have to adjust accordingly.Oh really now. Please explain to me the cause and effect. How is it that leaning agressively during taxi burns out a valve?? CHTs are well below 400 F. BHP is (or should be), well below 65%. Pressure within the cylinder is very low. So what is it that you know that engine experts such as Mike Busch don't know?
Burned out vavles have nothing to do with leaning during taxi; if anything agressively leaning during taxi helps to prolong valve life while taxiing with the mixture full rich is a detriment to valve life.
http://www.foxflying.com/engine_leaning.htm
http://www.avweb.com/news/airman/184502-1.html
http://www.swaircraftappraisals.com.../Operating Tips for Big-Bore Continentals.htm
You have just proved my point about pilots making non sequitur assumptions.
I don't think anyone said that all operator develop correct procedures. However, I'd put my money on at least a few currently exercised procedures being pioneered by operators and not engineers. Logic would tell me that this would be most likely in the places furthest from ideal conditions used for aircraft testing as they present opportunity. To fault all operator procedures because of examples like this, to me, seems like a non sequitur assumption.![]()
I can assure you there are no procedures in the book for the glider towing operations I do. (the book covers dusting and spraying ops.).
So basically, we do what other operators have had success with.
