Blackhawk
I lean aggressively during taxi. I didn't say that leaning aggressively during taxi caused burnt valves. What I said was that when a company changes something and has a problem go away, they tend to stick with it and its probably a good thing. Reading comprehension here man. I do know 207 operators that have said, "don't lean other than taxi," or "don't touch the mixture and stay below 1000'." Then they have the mixture adjusted to give about 18GPH at the cruise power setting. Nothing wrong with that if the company finds that its jug cracking / valve burning problem goes away in that particular kind of operation. An operation that has terrain to clear, and will have to frequently go above 1000' might have to adjust accordingly.
Again. I aggressively lean during taxi. I never said I didn't, and I've never heard of a company that said leaning was bad during taxi. But I do know of companies that have changed their policy on in flight leaning or stage cooling with good results. What companies do you know of that have told their pilots not to lean during taxi? Seriously. You want to talk about non-sequitor. Seriously though. Read what I wrote.
I read this part:
"This is not incorrect. Take all hangar talk with a boulder of salt. That said, when a company notices that they are burning through valves left and right, then changes a procedure, and suddenly the problem goes away, it might be an accurate diagnosis of a condition, or at least the technically incorrect logic behind whatever change they made had decent results."
This is my point. I guess I misunderstood what you wrote- it sounded like you were defending this premise and yes... I've heard this nonsense thrown around quite a bit.
When you change a condition and get a result you also need to make sure there is a correlation between the change and the result. Using the example of the burned valves. If a company changes their procedures and stops burning valves they need to also ensure they other conditions stayed the same. Were the cylinders with burned valves overhauled with the exact same valves and in the same way they were originally done? If not the cause may be a fault in the manufacture of the initial valves and using the procedure of leaning during taxi may be detrimental to valve longevity and may propagate false information and poor technique. This is how OWTs get born and propagated- someone in the field incorrectly correlates cause and effect. Again, I have nothing wrong with the operators in the field identifying and modifying procedures as they identify problems. They just need to make sure they correctly identify and correlate the cause and effect before they go monkeying with things.
