jdlilfan
I just scheduled another students CFI initial. Obviously of course through the local FSDO. This time though, the student wants to use two airplanes for the checkride. A C172R model and a PA28R-200 for the complex work. The PTS requires only the landings (short soft, 180 accuracy) and emergency procedure to be done in the complex right?
The FSDO examiner called the student and informed him that first of all, the checkride would consist of at least two days. He explained that this was due to two aircraft being used and the possibility of the oral lasting a whole day.
Second of all on the second or third day (depending on outcome), they would go up in the Arrow for some commercial manuevers including lazy 8's, steep spirals, chandelles, etc on top of the required landings and emergency procedures.
Can FSDO do this? For one making this into a two day checkride? But on top of that basically having two checkrides consisting of much of the same maneuvers in different planes?
I asked around at the FBO but no one seemed to have an explanation other than "well that's the FAA, what are you going to do about it"? Also, can they fail my student for doing something wrong in the Arrow when they did it correctly in the C172r? For instance, did a great lazy 8 in the C172 but the Arrow busted PTS? Even when the PTS wouldn't require them to do a lazy 8 in a complex aircraft? Could the FSDO inspector fail him or her for that?
I'm not looking forward to this examiner. He has quite a reputation. He fails guys for all kinds of stuff. Such as not knowing FAA form 337, not knowing the 8710 inside out, failing to brief the fire extinguisher in the plane, etc. His latest stunt for failing students is sliding off his seat belt during approach to landing. From what I understand it is not an obvious item, but he sneaks off the buckle and then hides the buckle with his hands in his lap. Btw, Do any other FSDO guys do this?
