Minuteman
I HAVE STRONG OPINIONS ABOUT AUTOMOTIVE LIGHTING!
Haha, it's not just the Truck though, the trailer needs a major overhaul as well... can we say boundary layer separation. And then every trailer out there needs to be like this.
Also as to the hybrids, I do not mean a hybrid like these retarded battery and gas things are. I mean a small diesel motor powering a large generator, running electric motors that drive the wheels. Just like trains work. No part of the IC engine provides movement. That is a terrible design(which is probably why they went with that for cars).
True. I did see a truck the other day that looked like someone had taken a bunch of coroplast, zipties & bailing wire and made an "aerodynamic skirt" for their semi-trailer. It looked like an accident waiting to happen, but there might have been some gain to be had before then.
I would imagine the size of the diesel engine needed to supply enough power to run an electric motor would be just about the same size as the existing diesels. The power band of the existing diesels is probably already quite narrow because they have have a history of marrying them to transmissions with a brazillion gears. But the diesel still has to accommodate a wide range of torques, which means changing mass flow and the turbocharger speed.
There may be some gain to be had with a hybrid system where the instantaneous power demand of the diesel motor is evened-out by spinning-up a flywheel (like F1's KERS) or charging a capacitor or battery during the low-demand segments, then drawing on that reserve when climbing a hill or running from the highway patrol when they see what the company has done to their trailer.
