Just doing some cocktail napkin figuring...
The specific power of avgas is around 11.9 kWh/kg. The best Lithium-polymer batteries are are achieving about 7 kWh/kg (so you have to carry more weight to have the same amount of portable power when comparing avgas and batteries). This is a heeeeyoge improvement over lead-acid batteries (0.18 kWh/kg) or Lithium-Ion batteries (0.3 kWh/kg).
However, the competition "heats" up when you consider efficiencies:
A typical O-360 application at 75% power will burn about 45 lb/hr. That works out to an effective specific power of 4.9 kWh/kg (an end-to-end efficiency of about 41%).
In an electric airplane, they need to achieve an end-to-end efficiency of 70% to have a specific power comparable to avgas. For electric motors in this power class it is reasonably expected to have efficiencies in the low-to-mid 90's (so there may be a net improvement in performance possible).
There are some additional implications to weigh:
- The power source mass doesn't decrease as it is used (which reduces range).
- There is no need for turbo-normalization to have sea-level motor performance.
- Prop speeds might be more like large turboprops than recips. (800-1200 rpm).
- The rule-of-thumb for charging a battery is to do it at a rate no faster than 10% of it's energy capacity (i.e., 10 hours for a full charge). Quick charging Li-Po batteries is possible, but it reduces battery life.
- No more Janitrol!
anic:
