So another question, has anyone ever checked the or trim for proper operation prior to a flight?
Required to each flight for my aircraft, insofar as cockpit operation and rigging, as well as trim cutouts and overrides for the electric side and such.
I do find it interesting that so many NTSB reports blame the pilot (even if in part) for anything thatbcould POSSIBLY be seen or checked. Saw it once on a cracked manifold incident. Pilot "should" have seen it on a preflight.
Other accidents due to a loss of flight controls (Wikipedia UA 232 page):
- In 2003, OO-DLL, a DHL Airbus A300 was struck by a surface-to-air missile shortly after departing from Baghdad International Airport, Iraq. The missile struck the portside wing, rupturing fuel lines and causing the loss of all three hydraulic systems. With the flight controls disabled the crew was able to use differential thrust to execute a safe landing at Baghdad. This is the first and only documented time anyone has managed to land a transport aircraft safely without working flight controls.
a DHL Airbus A300 was struck by a surface-to-air missile[/URL] shortly after departing from Baghdad International Airport, Iraq. The missile struck the portside wing, rupturing fuel lines and causing the loss of all three hydraulic systems. With the flight controls disabled the crew was able to use differential thrust to execute a safe landing at Baghdad. This is the first and only documented time anyone has managed to land a transport aircraft safely without working flight controls.
This is nothing short of awesome. Obviously, not the fact that it was him with a SAM, but the fact that crew landed it. Kudos to them!
Was on the ground at BIAP and watched that happen.
Post #9 here.
http://forums.jetcareers.com/genera...lane-leaving-baghdad-airport-damaged-sam.html
During cruise flight, the left aileron separated from one attach point, and the pilot executed a forced landing to a field. Prior to the accident flight, the airplane underwent maintenance for two outstanding service bulletins. During compliance with one of the service bulletins, the left aileron would have been removed and reinstalled. The pilot confirmed with the service center personnel that the maintenance on the airplane was completed and then proceeded to preflight the airplane. After departure, the airplane was level at 2,000 feet mean sea level (msl) for approximately one minute, the pilot noticed that the airplane began "pulling" to the left, and the left aileron was separated at one hinge attach point. The pilot then flew the airplane toward an unpopulated area, shutdown the engine, and deployed the aircraft's ballistic parachute system. Subsequently, the airplane descended to the ground with the aid of the parachute canopy and came to rest upright in a field of mesquite trees. Examination of the left aileron and the airframe aileron hinges revealed that the outboard aileron hinge bolt was missing, and no evidence of safety wire noted. According to maintenance manual procedures, the bolt and washer hardware were to be torqued to a measured 20-25 inch pounds, then safety wired to a actuation fitting. After installation, the manual required a verification of proper hinge bolt installation and torque on the outboard hinge.
The National Transportation Safety Board determines the probable cause(s) of this accident as follows:
The improper reinstallation of the left aileron by maintenance personnel. A contributing factor was the non-suitable terrain for the forced landing.
Ask AF one morning about how his trim was rigged backwards in the Chieftain once.
Dude is lucky to be alive, but Amflight is also lucky that it happened to one of their best pilots.
Flight control check before takeoff?
Doesn't sound like the best pilot to me if he missed that.
We have the same check on the Lear 45. Guess what? You can't see the ailerons from the cockpit, or the elevator or the rudder. See what I'm getting at? We check to see if the spoilerons activate base on their position on a display in the cockpit. That and the trim are the only flight controls we can tell the position of (from the cockpit, after engine start). It's a two crew aircraft and no where in the checklist does it have one of us wiggle the ailerons and the other check their position from the outside. So, on most if not all transport category A/C I can only assume it's the same.
Yes, I realize a cheiften isn't transport category, but having never flown one I can't assume you can see the controls. Remember, less talky, more reeedy. I mostly lurk on here as I KNOW I have a ton to learn and less to comment on. Even with my ATP and type.
We have the same check on the Lear 45. Guess what? You can't see the ailerons from the cockpit, or the elevator or the rudder. .
I'm studding for the ATP and one of the questions asks about NTSB reports and flight control malfunction. I think this is probably one of my largest concerns in aviation. In college, a lot of accident studies were covered, but none attributed flight control failure as one of them. Has anyone seen an accident that was due to a cable snapping or something along those lines?
I've heard of ailerons being installed in reverse, and I guess there is that video on the 'net that has an airbus go into a forest during a demonstration...
