it will now be '60k and beating around in a 172 for 3 years making 30k or less with no upward mobility only to start over again at the bottom of the regional payscale - no thanks'
And I think this has been covered in previous threads on this topic but just to be sure...previously hired 121 pilots with less than 1,500 hrs will be grandfathered in when the new rule takes effect...is that correct?
There is nothing to be grandfathered.
Individuals hired into positions based off of current (at the date of hire) legislation can not be held against a new standard established after their date of hire with a company.
That said, by the time the legislation is active come 2012/2013 (because if I'm not mistaken there is going to be a 2-4 year grace period) there will be very few < 1500TT pilots at any 121 operators.
When flights start getting cancelled, so will this policy. Now how about 10 hours rest behind closed doors?
IMO, we don't need some complicated matrix or when duty starts or number of legs past a certain time. 12 hours of duty MAX followed by 12 hours of rest. Duty is defined as ANYTIME the crewmember is responsible to the company. If you have to be available by pager, phone, bat signal or smoke signal IT IS DUTY. Rest is the time spent AT a location suitable for rest. Complete 12 hours of duty and it takes you 2 hours to get to the hotel. No problem, your rest doesn't start until you get into your room. Duty begins as soon as you leave the hotel or suitable rest area.
No more flight time limits, fly as much as you want in 24 hours, 7 days, month, year, etc.
That is exactly what will happen before any raises in pay happen.. "well that's what your contract says."When flights start getting cancelled, so will this policy. Now how about 10 hours rest behind closed doors?
Demand will pass supply, and that is when pilots will have the upper hand...
... to the end of Gulfstream Academy :beer:
You see the trouble with this is that some of our peers consider layovers time off away from home, so what's it matter if it's 8 hours or 12 hours...fatigue? What's that?
My point is that time has only a small part to play in the matter. I think it's a bit ill conceived to think that a 300 hour pilot isn't CAPABLE of safely performing the duties of FO/SIC. Airlines should make sure they are capable through training and testing and I believe in most instances they do.
And you hit a point that proves we are our own worst enemies. The same people that will commute in at midnight for a 5 am show are the same ones to cry about fatigue.
I really feel there should be a check in/out system that the FEDs monitor for duty and rest.
And yes, you can go through the NTSB archives and find plenty of accidents that involve high time crews, but I can also tell you plenty of stories where the only thing keeping the plane I was flying out of the dirt was me because if I wasn't there for some reason the guy in the right seat sure as hell wouldn't have been able to keep the plane in the air. And that was just on a normal operations day. No weather. No fatigue. No MX issues.
Judging by experience I don't think that is the case. I can start the trip on 4-5 hours of sleep the night before, that is not what kills me. What kills me is 3-4 days of that with swapping circadian rhythms.
Here is a good one that illustrates your point..
http://www.ntsb.gov/ntsb/brief.asp?ev_id=20081003X17330&key=1
The thought process will no longer be 'Sure its 60k and one year of bad pay, but at least I'm in a shiny jet with a future!'... it will now be '60k and beating around in a 172 for 3 years making 30k or less with no upward mobility only to start over again at the bottom of the regional payscale - no thanks' (sorry that was long, but hopefully it made sense)
The first day I am fine, I think I know when I am tired or not.
