Douglas
Old School KSUX
- Actually: It works exceptionally well in the Cherokee 6 and I use the technique on a regular basis. Johnson bar flaps are da bomb.
I've never flown the Six. Is it mechanical, Electrical, Hydraulic?
obviously...Well, i obviously have a superior mind because i never used any of those words.![]()
I'm a nancy because I want to do things that won't bend metal?
Check it out, boss, if you can't put a 172 down on a 1,800 turf runway without putting the flaps out as soon as you're on the ground, you need some remedial training.
Ahhh man, I can't believe I missed your arrival John!
Look, the world is not black and white. You can't just say, "DON'T EVER DO X" because someone will come up with a scenario where you can and should do X.
As for raising the flaps, some times its the only way to maintain directional control during the roll out on a really muddy day when a tire digs in more than another, or the airplane's still trying to fly because of 40kt gusts is to suck the flaps up. Its not wrong, its just different from what you did.
Bear in mind that your about 1500hrs of experience was essentially limited to instructing (in one form or another a la Amflight) and FO-ing. Which means that in many circumstances your experience doesn't explore non-PTS, or non-standard situations that might arise from boundary conditions which cannot be found in the realm of Skymates, Amflight, or ExpressJet. This is not a bad thing, its just different. Its not that you weren't experienced in what you were doing, but rather your experience doesn't prepare you for all possible types of flying (just as mine doesn't prepare me for flying down south).
Here's an example of when the float plane would need as much room as possible to get in, but potentially less to get out. Envision a lake on the most awesome day ever the wind is calm, and the water, unfortunately is glassy. Depending on the dimensions and local topography of your lake, it may be possible for you to have to come in over some fairly steep terrain, that you wouldn't have to worry about on the departure but provides the best possible "last reference point" for a glassy water landing. That 150' might be the difference between going around and successfully landing when you're descending to the lake essentially on instruments.
Or perhaps on a river that is filled up with boat traffic limiting your landing distance that will be gone by the time you leave.
For the wheel plane pilot, the adventure of flying in exceedingly windy conditions can sometimes required a different technique. With 40kt gusts it is very easy for even a fairly heavy light airplane to be picked up and thrown around. If you get into these gusts close to the ground, where it counts, and the mechanical turbulence doesn't really help you you may be in a position where you could end up flying again with too little control to shove the nose down. In the winter up here these are conditions that exist, and can require different techniques as a solution.
Ever landed on fresh snow in a light piston single? The deceleration is such that you don't need to use brakes. When trying to take off again, it can be more complicated some times you have to do things like lift a tire out of the snow so that you accelerate then dump full flaps to suck the other one out once you get to flying speed. This is a fairly abnormal experience, but it happens.
Finally, as for your jab at Esa, what was the shortest strip you ever went into, and how heavy were you? I suspect that an 1800' strip on a 110 degree day in texas could be an exciting experience, especially if one were at max gross.
I still think it laughable that anyone on here thinks that retracting flaps in a 172 with the electric flaps that take 10 seconds to come up does ANYTHING to reduce your ground roll.
Carry on with the flamewar.
Thank you for that explanation. If i were to try and explain exactly how things wprked, like jerking the flpas and the yolk at the same time to get air born, i would get run out of the forum. The fact is, its a SOP over here. Sometimes you gotta do what you gotta do.
If it is in the POH then scan it and post on here.
What, that old thing? Does anybody even read the POH anymore?
Honestly, I've never thought this was a sensible argument. The flap lever and the gear handle are shaped entirely differently (one's shaped like a wheel and the other is shaped like a flap) and I've never seen an installation where they were physically anywhere close to each other.
If you can't instantly tell by feel which handle you've got your hand on, you probably shouldn't be at the controls of anything, let alone an airplane.
A big "yeah that" to that.
My favorite feeling in the world until I discovered the joy of pulling a float out of the water was the feeling of acceleration when you pulled the tires out of lose snow in a 207 by adding flaps and using a little aileron. A swift jerk in some airplanes can pull the mains out of the snow or mud and get you flying a little too slow to climb but high enough to begin accelerating. It's just different than hitting vr and rotating.
Most days I pull the nose wheel off the ground about an inch or so as soon as I have the downwash to do it, then accelerate until I can add a little flap and get airborne. That's SOP up here as far as I'm concerned. On gravel sometimes pulling the nosewheel up out of the mud an inch or so gives you the necessary acceleration to climb out. Down here in southeast we've got the advantage of having good paved runways for pretty much every place except Excursion Inlet, in the rest of the state, that's pretty abnormal. Take a look at this stuff:
[YT]hwje6_LDiJZg[/YT]
[YT]kI488_QAMSc[/YT]
This dude really knows the planning attitude.
[YT]42TA5ZWMQZU[/YT]
that glassy water landing is insane. I'll never see anything like that here in the bayou. I need to get to alaska once my time is up down here.
