Best six seat single
Interesting.
I think the prices are relatively fair.
Also, in reading the Cessna pilot forums, most owners say mx isn't a huge deal other than the exhaust system which requires a 50 hour inspection and the cylinders need a topper usually at half life.
They're fast and capable, but it will come with a price both in purchasing and maintenance.
Isn't having a price in both purchase and maintenance kind of given once your mission becomes moving 5 people 500 miles at 15k? With a mission like that, seems to me you're going to have to get used to writing checks with lots of zeros no matter what model you choose.
The 210 has a reputation for being a plane that will lift anything you can pack it full of. I think you tend to find more 210's being used to fly freight than Bonanza's or Cherokee six/Lance/Toga's. There has to be a reason for that.
I would say A-36 but you said "for the money".
The saratoga is a truck and cheap. It will hold 100 gallons and have 600 pounds of useful load left. If you are only going 500 miles, you won't need full tank and should be able to fit five, if they aren't huge.
It's a bit slow, but hey.
Since you only need 4-5 seats that helps. I would suggest a Howard DGA-15P. Pratt & Whitney R985 (12:1 Blower), Bench seating three in the back so you have capacity for 5 people. no problem with five people and 500 mile range (fuel capacity 121 gallons). Price range between $75-$150k. The airplane will not depriciate unless you groundloop it.
:drool:
It will carry much, much more than 600 lbs.
I second the Piper. Saratoga is the way to go. Its comfortable and will get the job done.
Plus, I have a soft spot for it in my heart. Its a fun airplane to fly.
I withdraw my suggestion and agree with Waco ;)
Plus they are easier to work on than a dirt bike (at least the older Pipers are). Seriously, systems are laughably simple and most things are in easy reach, esp. compared to a Cessna.
That was my Grandpa's airplane. Very stable, pretty fast, comfortable, and it made a neat noise. I sold it to a guy who took real good care of it, but then needed to take on a partner. A Naval test pilot bought a share, and my friend gave him 50 hrs dual. Shortly after that the guy substantially mangled the airplane. It is somewhere in Oklahoma being rebuilt now I think.
EDIT: The guy who groundlooped this also dinged a Cabin Waco within the same week that he did the Howard.
We had a cabin Waco at our local airport open house once, beautiful airplane. The guy was turning around in the runup area on his way home and knocked the vertical tail off of a Cessna 152.
Tower had to tell him what he had done when he called for takeoff... damage to the Waco was minimal ;)
Yeah, I don't have the book in front of me any more. A school I worked for a couple of years ago had one on the line, with A/C. That's the number I remember though.
----Edit:
Alright, I looked it up. You are correct. :)
Well, if you are flying over mountains I would suggest a twin, but since you asked for a single, I think a T210N would fit your mission very well.
----Edit:
Specifications (1972 model PA-32RT-300)
Data from 1972 Piper Lance Owner's Handbook
General characteristics
Crew: One
Capacity: five passengers (optional additional seat on some)
Length: 27 ft 9 in (8.44 m)
Wingspan: 32 ft 10 in (9.99 m)
Height: 9 ft 6 in (2.9 m)
Wing area: 174.5 ft² (16.2 m²)
Wing profile: NACA 65-415
Empty weight: 2011 lb (912 kg)
Gross weight: 3600 lb (1633 kg)
Powerplant: One × Lycoming IO-540-K1G5, 300 hp (225 kW) each
Performance
Maximum speed: 190 mph (306 km/h)
Cruise speed: 160 mph (258 km/h)
Range: 1000 miles (1600 km)
Service ceiling: 14600 ft (4450 m)
Rate of climb: 1050 ft/min (5.3 m/s)
This is what Wikipedia says about an older piper. I did some google searches about newer T-Saratogas and they pretty much echoed around the 600-700 lbs of useful load at full fuel, but it carries a ton of fuel for a single.
The newer Saratogas don't have the useful load that the older ones did. We had one that I flew about 50 hours in that only had a 1100# useful load. It did have air conditioning but that's only about 60#. I like the way the PA32 flies. I think the Bonanza is a better built airplane overall but I don't like the way it flies. If you have somebody in the back row of the Bonanza you better hope they don't get seasick (even straight tail models). The useful load on those isn't really that great either. Super expensive, also.
T210s haul ass and hold a lot.
Im guessing a piston single not a turbine single.
Don't waste your time with a Beech "Banna". There expensive to maintain and narrow CG. I would suggest a Turbo Lance if its a cheap purchase price or a T210 a M model or later.
Might I suggest checkin out this fine 210!
http://www.ksl.com/index.php?nid=218&ad=10228175&cat=151&lpid=
Also this has the Ekstar STC. Which gives you tanks topped off and 1000lbs of junk in the trunk to play with.
Don't agree with the above poster I think the Banna flies great love the club seating but there expensive to maintain and have a picky CG on the A36TC's. Which I wouldn't suggest for a PHX area plane the A models didn't have cowl flaps and you can easily burn it up with out a nice EGT/CHT gauge.
The Howard for sure.
If you're not man enough for it, then a T210. Definitely the most capable plane out there in its class, IMO. Fill it up with gas and people and dont even worry about W&B. It just isnt an issue.
