Best six seat single
So what is it for the money?
Turbocharged is a must!
What's the mission?
For a cross country machine, I'd say 210/Saratoga Retract, for trips that are consistently less than 1hr with the capability for off airport work, I'd go with the 206/207, with a heavy emphasis on the 207.
If its for airtaxi work, I'd ditch the turbo and deal with the pisspoor climb rates.
Also, are you going to be hauling stuff? The PA32 consistently cubes out before the 207 series imo.
For little money, a cherokee 6/saratoga/lance.
For a little more money, 206.
Basing an airplane solely on money isn't a great idea. What do you want to do with it?
I've got a client looking for one and we've settled on a Malibu Mirage with a half or a third share of a TBM 700/850 not out of the question either.
If it were me and I had his cash I'd also be thinking about a C-208.
What kind of fields are you going into and out of? Improved, or rough strips? Do you need turbocharging because of denalt? or for other reasons?
Improved.
Density altitude and the ability to fly above the mountainous terrain in my area (15,000 in some places).
There are a few fixed gear turbocharged Saratogas out there, club seating, decent useful load, nose baggage bin and larger inside than a 206 by a bit.
Quest Kodiak!
Since you only need 4-5 seats that helps. I would suggest a Howard DGA-15P. Pratt & Whitney R985 (12:1 Blower), Bench seating three in the back so you have capacity for 5 people. no problem with five people and 500 mile range (fuel capacity 121 gallons). Price range between $75-$150k. The airplane will not depriciate unless you groundloop it.
Consider looking at the A36 Bonanza. Usually, when a conversation comes up involving the C206 and PA32, the A36 is right there. I know there are some turbo-normalized A36's out there, but they aren't likely to be in the same price range as a PA32 or C206
Personally, I'd go with a Turbo Saratoga fixed gear if you're going for something older, or a newer turbo 206 (with the Lycoming) if your budget is for something newer. The older Pipers like the 80s fixed gear 'Togas have dirt simple systems which will save you a bundle on mx versus something newer and fancier. It might be hard to find a turbo one for sale in decent shape though.
