Again, elevator controls AOA (not airspeed OR altitude)
What does AOA control?
- L is lift force,
- ρ is air density
- v is true airspeed,
- A is planform area, and
- CL is the lift coefficient at the desired angle of attack, Mach number, and Reynolds number[43]
The lift coefficient is dependent on the AOA. If the AOA goes up then CL goes up and something else in the lift equation must change to keep lift and weight balanced. By the other variables in the formula: air density, true airspeed, and planform area, only one can logically change. So we conclude that a change in AOA must be accompanied by a change in in airspeed to keep our happy L=W balance.
Seems you agree with us eggheads without realizing it.
Roger said:
and throttle controls power output (not airspeed OR altitude).
I will steal our next image from tgrays website:
What this depicts is Vy being the point at maximum excess in power. We climb or descend because of an excess or lack of power available over power required. Let's assume a glider in a perfectly stable (IE no lifting/sinking/moving air) air mass. Released at 2,000 feet, at MCA (for the wise guys that will comment on this), ever reach 2,001 feet? No.
Point is, power will always yield altitude. You must pitch forward when you increase power, lowering AOA, which we discovered earlier increases airspeed, to get a speed increase from applying power. However, the power didn't increase the speed. The power tried to make you climb. Your pitch change increased the speed.
ajf005 said:
Theres no set in stone law that works every time for different variables.
But there are instincts that won't kill you and instincts that can kill you. Our job when teaching a private pilot is to ensure that their instincts are based on basic physical law because any other premise can be deadly.
ajf005 said:
what are you going to teach on an ILS when the student gets fast?
shdw said:
The goal with a private pilot is primacy and instinct, in other words safe habit patterns.
To all: Those of you saying "beating a dead horse." Consider this: we have 100's of members a day that read these forums and do not post. If one of those readers has an engine failure in the future and remembers reading this thread, it could save their life. That alone makes this worth it to me.
Important topics, such as this, should be debated repeatedly and often until the majority sees the steady truths versus the shaky, often illogical, opposition on the subject.
Disclaimer: Again, I am only speaking for light piston aircraft and primary students.
